查看: 1926|回复: 2
C 语言问题 求助!
发表于 2009-6-4 03:56:18 | 显示全部楼层 |阅读模式
Design a revolving bank door with infra red sensors and a stepper motor
If the beam is broken the door must turn in one direction to allow access to the bank. If the other beam is broken the door must turn in the opposite direction(obviously only when there is somebody inside). When the beams are broken, prompt the user for a Name and Surname. Save this information in a structure called Person.
The GUI shold display the system time and number of people in the bank. A log file shold be kept. This file contains the Time In an Out as well as the name and surname of the person
If somebody tries to access the system between 5pm and 8:30am an alarm must sound and an appropriate message should be displayed on the screen (hint: time. h)
Thanks so much!
发表于 2009-6-6 21:48:15 | 显示全部楼层
使用单片机吗?看起来硬件方面的成分更多。
 楼主| 发表于 2009-6-7 17:24:59 | 显示全部楼层
不是,只是用C语言写一个程序出来就够了!  不能PIC写
GMT+8, 2025-12-7 18:56 , Processed in 0.017114 second(s), 7 queries , Gzip On, Redis On.
