查看: 4602|回复: 3
[原创]H-JTAG 调试代理软件
发表于 2006-4-7 20:11:14 | 显示全部楼层 |阅读模式
最近更新:2006-04-02 (请到我的BLOG下载 Http://twentyone.blogchina.com)
H-JTAG是一个免费的ARM调试代理,程序没有任何限制,希望能给ARM的爱好者提供一
个简单实用的学习工具。欢迎访问我的BLOG: http://twentyone.blogchina.com
我的blog提供了安装程序的下载,同时,也提供了常见的Q&A.
  0. 支持ARM7/ARM9,支持自动检测和手动指定内核
  1. 使用RDI接口,支持SDT,ADS,REALVIEW和IAR
  2. 支持ADS1.2和SDT2.51和RREAL VIEW
  3. 支持个硬件断点或者数量不限的软件断点
  4. 支持ARM/THUMB模式
  5. 支持LITTLEENDIAN & BIGENDIAN
  6. 支持SEMIHOSTING
  7. 支持WIGGLER SDTJTAG和自定义接口
H-JTAG在以下ARM处理器上测试过:
  S3C4510(ARM7TDMI)
  S3C44B0(ARM7TDMI)
  S3C2410(ARM920T)
  S3C2440(ARM920T)
  LPC系列处理器(ARM7TDMI-S)
  AT91R40008(ARM7TDMI)
  AT91RM9200(ARM920T)
如果你有上面没有列出来的ARM板子,而且愿意帮助我进行测试的话,欢迎和我联系。
在此,谢谢所有的热心帮助过我的朋友们。谢谢你们的支持!
H-JTAG常见问题Q&A
Q. Unable to load h-jtag driver
A. It means that the driver for h-jtag hasn't been installed properly.
   Please reinsrall h-jtag with the administrator's right.
Q. Too many breakpoints
A. Normally, this is caused by vector catch/semihosting. Enable vector
   catch/semihosting will consume the breakpoint resource. If all the
   breakpoint resources are occupied, this message may be displayed.
   Please note that all the breakpoints set for vector catch and semihosting
   are unvisible to users. These breakpoints can't be removed by "delete all
   breakpoint" command. To remove this message, please disable the vector
   catch and semihosting in your debugger setting.
Q. The statement into which was stepped is singular (i.e. it has no exit)
A. This is caused by unvisible breakpoint set for vector catch/semihosting.
   To remove this message, please disable vector catch in your debugger
   setting.
Q. Execution stopped, because of an unknown breakpoint (this indicates an
   internal error).
   setting.
Q. The processor is reset
A. To remove this message, please disable vector catch in your debugger
   setting.
Q. Unrecognized swi
A. To remove this message, please disable semihosting in your debugger
   setting.
发表于 2006-4-23 00:30:23 | 显示全部楼层
[原创]H-JTAG 调试代理软件
你的blog那里可以下载么啊
发表于 2010-9-13 07:11:04 | 显示全部楼层
咳,我的easyJTAG-H ,ADS1.2怎么装不了H-JTAG.DLL,不会啊,老是错,这个H-JTAG.dll是不是装H-JTAG产生的啊
发表于 2010-11-5 01:22:33 | 显示全部楼层
thanks!
GMT+8, 2025-12-21 21:22 , Processed in 0.025522 second(s), 7 queries , Gzip On, Redis On.
