楼主: zzhan123
PT-2009.06 upload
发表于 2012-7-27 15:48:58 | 显示全部楼层
都么钱了,,,
发表于 2013-7-23 16:50:58 | 显示全部楼层
module decode (datain, dispin, dataout, dispout, code_err, disp_err) ;
  input [9:0]   datain ;
  input                dispin ;
  output [8:0]        dataout ;
  output        dispout ;
  output        code_err ;
  output        disp_err ;
  wire ai = datain[0] ;
  wire bi = datain[1] ;
  wire ci = datain[2] ;
  wire di = datain[3] ;
  wire ei = datain[4] ;
  wire ii = datain[5] ;
  wire fi = datain[6] ;
  wire gi = datain[7] ;
  wire hi = datain[8] ;
  wire ji = datain[9] ;
  wire aeqb = (ai & bi) | (!ai & !bi) ;
  wire ceqd = (ci & di) | (!ci & !di) ;
  wire p22 = (ai & bi & !ci & !di) |
             (ci & di & !ai & !bi) |
             ( !aeqb & !ceqd) ;
  wire p13 = ( !aeqb & !ci & !di) |
             ( !ceqd & !ai & !bi) ;
  wire p31 = ( !aeqb & ci & di) |
             ( !ceqd & ai & bi) ;
  wire p40 = ai & bi & ci & di ;
  wire p04 = !ai & !bi & !ci & !di ;
  wire disp6a = p31 | (p22 & dispin) ; // pos disp if p22 and was pos, or p31.
   wire disp6a2 = p31 & dispin ;  // disp is ++ after 4 bits
   wire disp6a0 = p13 & ! dispin ; // -- disp after 4 bits
  wire disp6b = (((ei & ii & ! disp6a0) | (disp6a & (ei | ii)) | disp6a2 |
                  (ei & ii & di)) & (ei | ii | di)) ;
  // The 5B/6B decoding special cases where ABCDE != abcde
  wire p22bceeqi = p22 & bi & ci & (ei == ii) ;
  wire p22bncneeqi = p22 & !bi & !ci & (ei == ii) ;
  wire p13in = p13 & !ii ;
  wire p31i = p31 & ii ;
  wire p13dei = p13 & di & ei & ii ;
  wire p22aceeqi = p22 & ai & ci & (ei == ii) ;
  wire p22ancneeqi = p22 & !ai & !ci & (ei == ii) ;
  wire p13en = p13 & !ei ;
  wire anbnenin = !ai & !bi & !ei & !ii ;
  wire abei = ai & bi & ei & ii ;
  wire cdei = ci & di & ei & ii ;
  wire cndnenin = !ci & !di & !ei & !ii ;
  // non-zero disparity cases:
  wire p22enin = p22 & !ei & !ii ;
  wire p22ei = p22 & ei & ii ;
  //wire p13in = p12 & !ii ;
  //wire p31i = p31 & ii ;
  wire p31dnenin = p31 & !di & !ei & !ii ;
  //wire p13dei = p13 & di & ei & ii ;
  wire p31e = p31 & ei ;
  wire compa = p22bncneeqi | p31i | p13dei | p22ancneeqi |
                p13en | abei | cndnenin ;
  wire compb = p22bceeqi | p31i | p13dei | p22aceeqi |
  wire compc = p22bceeqi | p31i | p13dei | p22ancneeqi |
                p13en | anbnenin | cndnenin ;
  wire compd = p22bncneeqi | p31i | p13dei | p22aceeqi |
  wire compe = p22bncneeqi | p13in | p13dei | p22ancneeqi |
  wire ao = ai ^ compa ;
  wire bo = bi ^ compb ;
  wire co = ci ^ compc ;
  wire do = di ^ compd ;
  wire eo = ei ^ compe ;
  wire feqg = (fi & gi) | (!fi & !gi) ;
  wire heqj = (hi & ji) | (!hi & !ji) ;
  wire fghj22 = (fi & gi & !hi & !ji) |
                (!fi & !gi & hi & ji) |
                ( !feqg & !heqj) ;
  wire fghjp13 = ( !feqg & !hi & !ji) |
                 ( !heqj & !fi & !gi) ;
  wire fghjp31 = ( (!feqg) & hi & ji) |
                 ( !heqj & fi & gi) ;
  wire dispout = (fghjp31 | (disp6b & fghj22) | (hi & ji)) & (hi | ji) ;
  wire ko = ( (ci & di & ei & ii) | ( !ci & !di & !ei & !ii) |
                (p13 & !ei & ii & gi & hi & ji) |
                (p31 & ei & !ii & !gi & !hi & !ji)) ;
  wire alt7 =   (fi & !gi & !hi & // 1000 cases, where disp6b is 1
                 ((dispin & ci & di & !ei & !ii) | ko |
                  (dispin & !ci & di & !ei & !ii))) |
                (!fi & gi & hi & // 0111 cases, where disp6b is 0
                 (( !dispin & !ci & !di & ei & ii) | ko |
                  ( !dispin & ci & !di & ei & ii))) ;
  wire k28 = (ci & di & ei & ii) | ! (ci | di | ei | ii) ;
  // k28 with positive disp into fghi - .1, .2, .5, and .6 special cases
  wire k28p = ! (ci | di | ei | ii) ;
  wire fo = (ji & !fi & (hi | !gi | k28p)) |
            (fi & !ji & (!hi | gi | !k28p)) |
            (k28p & gi & hi) |
            (!k28p & !gi & !hi) ;
  wire go = (ji & !fi & (hi | !gi | !k28p)) |
            (fi & !ji & (!hi | gi |k28p)) |
            (!k28p & gi & hi) |
            (k28p & !gi & !hi) ;
  wire ho = ((ji ^ hi) & ! ((!fi & gi & !hi & ji & !k28p) | (!fi & gi & hi & !ji & k28p) |
                            (fi & !gi & !hi & ji & !k28p) | (fi & !gi & hi & !ji & k28p))) |
            (!fi & gi & hi & ji) | (fi & !gi & !hi & !ji) ;
  wire disp6p = (p31 & (ei | ii)) | (p22 & ei & ii) ;
  wire disp6n = (p13 & ! (ei & ii)) | (p22 & !ei & !ii) ;
  wire disp4p = fghjp31 ;
  wire disp4n = fghjp13 ;
  assign code_err = p40 | p04 | (fi & gi & hi & ji) | (!fi & !gi & !hi & !ji) |
                    (p13 & !ei & !ii) | (p31 & ei & ii) |
                    (ei & ii & fi & gi & hi) | (!ei & !ii & !fi & !gi & !hi) |
                    (ei & !ii & gi & hi & ji) | (!ei & ii & !gi & !hi & !ji) |
                    (!p31 & ei & !ii & !gi & !hi & !ji) |
                    (!p13 & !ei & ii & gi & hi & ji) |
                    (((ei & ii & !gi & !hi & !ji) |
                      (!ei & !ii & gi & hi & ji)) &
                     ! ((ci & di & ei) | (!ci & !di & !ei))) |
                    (disp6p & disp4p) | (disp6n & disp4n) |
                    (ai & bi & ci & !ei & !ii & ((!fi & !gi) | fghjp13)) |
                    (!ai & !bi & !ci & ei & ii & ((fi & gi) | fghjp31)) |
                    (fi & gi & !hi & !ji & disp6p) |
                    (!fi & !gi & hi & ji & disp6n) |
                    (ci & di & ei & ii & !fi & !gi & !hi) |
                    (!ci & !di & !ei & !ii & fi & gi & hi) ;
  assign dataout = {ko, ho, go, fo, eo, do, co, bo, ao} ;
  // my disp err fires for any legal codes that violate disparity, may fire for illegal codes
   assign disp_err = ((dispin & disp6p) | (disp6n & !dispin) |
                      (dispin & !disp6n & fi & gi) |
                      (dispin & ai & bi & ci) |
                      (dispin & !disp6n & disp4p) |
                      (!dispin & !disp6p & !fi & !gi) |
                      (!dispin & !ai & !bi & !ci) |
                      (!dispin & !disp6p & disp4n) |
                      (disp6p & disp4p) | (disp6n & disp4n)) ;
endmodule
发表于 2014-4-7 10:58:58 | 显示全部楼层
hao dongxi
发表于 2014-4-7 10:59:38 | 显示全部楼层
这么多啊
发表于 2014-4-7 11:00:28 | 显示全部楼层
bucuo
发表于 2014-4-7 11:01:31 | 显示全部楼层
为了下载啊
发表于 2014-4-7 11:02:31 | 显示全部楼层
好东西
发表于 2014-4-7 11:05:04 | 显示全部楼层
下了先看
发表于 2014-4-7 12:35:03 | 显示全部楼层
好东西
发表于 2014-4-7 12:35:58 | 显示全部楼层
太多了
GMT+8, 2025-12-26 16:00 , Processed in 0.017719 second(s), 2 queries , Gzip On, Redis On.
