查看: 1957|回复: 0
arm7:AT91M40800設置NCS1出現問題,請教各位大蝦!
发表于 2006-3-15 10:28:39 | 显示全部楼层 |阅读模式
設置的程序如下可是NCS1卻沒有片選信號輸出)
#define EBI_CSR_0       ((unsigned int )(FLASH_BASE | 0x2539))
#define EBI_CSR_1       ((unsigned int )(0x10000000|0x20a5))
#define EBI_CSR_2       ((unsigned int )(0x20000000))
#define EBI_CSR_3       ((unsigned int )(0x30000000))               /* unused */
#define EBI_CSR_4       ((unsigned int )(0x40000000))               /* unused */
#define EBI_CSR_5       ((unsigned int )(0x50000000))               /* unused */
#define EBI_CSR_6       ((unsigned int )(0x60000000))               /* unused */
#define EBI_CSR_7       ((unsigned int )(0x70000000))               /* unused */
請各位大蝦指點一下!多謝!
GMT+8, 2025-12-19 18:18 , Processed in 0.022878 second(s), 6 queries , Gzip On, Redis On.
