查看: 21807|回复: 54
[ebook]Hardware Implementation of Finite-Field Arithmetic
发表于 2009-5-27 08:29:03 | 显示全部楼层 |阅读模式
[size=120%]Hardware Implementation of Finite-Field Arithmetic (Electronic Engineering)
By Jean-Pierre Deschamps
  • Publisher:   McGraw-Hill Professional
  • Number Of Pages:   360
  • Publication Date:   2009-02-19
  • ISBN-10 / ASIN:   0071545816
  • ISBN-13 / EAN:   9780071545815
Product Description:
Implement Finite-Field Arithmetic in Specific Hardware (FPGA and ASIC)
Master cutting-edge electronic circuit synthesis and design with help from this detailed guide. Hardware Implementation of Finite-Field Arithmetic describes algorithms and circuits for executing finite-field operations, including addition, subtraction, multiplication, squaring, exponentiation, and division.
This comprehensive resource begins with an overview of mathematics, covering algebra, number theory, finite fields, and cryptography. The book then presents algorithms which can be executed and verified with actual input data. Logic schemes and VHDL models are described in such a way that the corresponding circuits can be easily simulated and synthesized. The book concludes with a real-world example of a finite-field application--elliptic-curve cryptography. This is an essential guide for hardware engineers involved in the development of embedded systems.
Get detailed coverage of:
  • Modulo m reduction
  • Modulo m addition, subtraction, multiplication, and exponentiation
  • Operations over GF(p) and GF(pm)
  • Operations over the commutative ring Zp[x]/f(x)
  • Operations over the binary field GF(2m) using normal, polynomial, dual, and triangular
Hardware Implementation of Finite-Field Arithmetic.rar
1.18 MB, 下载次数: 595 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-5-27 12:41:04 | 显示全部楼层
ex. used for RS codec?
发表于 2009-5-29 09:15:08 | 显示全部楼层
Thanks a  lot l!!!!!!!!!!!!!!!!!
发表于 2009-5-29 09:21:53 | 显示全部楼层
bu cuo
发表于 2009-5-30 18:59:20 | 显示全部楼层
gf上的东西还是可以学习的
发表于 2009-5-30 22:02:11 | 显示全部楼层
good, thanks
发表于 2009-5-30 22:04:34 | 显示全部楼层
good, thanks
发表于 2009-6-4 08:06:27 | 显示全部楼层
Thanks a lot.
发表于 2009-6-5 10:38:44 | 显示全部楼层
当年毕业课题就是做FFA方面的,TKS!
发表于 2009-7-15 14:04:32 | 显示全部楼层
Thanks for your share!
GMT+8, 2025-12-28 05:27 , Processed in 0.024083 second(s), 6 queries , Gzip On, Redis On.
