查看: 4464|回复: 0
x264 有一个denoise的程序,怎么理解?
发表于 2009-5-24 18:17:37 | 显示全部楼层 |阅读模式
程序如下: 感觉是一个低通滤波,但不知道是什么原理?各位高手指点下,万分感谢
static void x264_denoise_dct( int16_t *dct, uint32_t *sum, uint16_t *offset, int size )//*sum就是h->nr_residual_sum, *offset就是h->nr_offset
    int i;
    for( i=1; i<size; i++ )
        int level = dct;
        int sign = level>>15;
        level = (level+sign)^sign;
        sum += level;
        level -= offset;
        dct = level<0 ? 0 : (level^sign)-sign;
void x264_noise_reduction_update( x264_t *h )
    int cat, i;
    for( cat = 0; cat < 2; cat++ )
        int size = cat ? 64 : 16;
        const uint16_t *weight = cat ? x264_dct8_weight2_tab : x264_dct4_weight2_tab;
        if( h->nr_count[cat] > (cat ? (1<<16) : (1<<18)) )
            for( i = 0; i < size; i++ )
                h->nr_residual_sum[cat] >>= 1;
            h->nr_count[cat] >>= 1;
            h->nr_offset[cat] =
                ((uint64_t)h->param.analyse.i_noise_reduction * h->nr_count[cat]
                 + h->nr_residual_sum[cat]/2)
              / ((uint64_t)h->nr_residual_sum[cat] * weight/256 + 1);
GMT+8, 2025-12-15 18:27 , Processed in 0.029455 second(s), 5 queries , Gzip On, Redis On.
