查看: 2387|回复: 3
about dbm/200khz problem..
发表于 2009-5-22 22:54:15 | 显示全部楼层 |阅读模式
Dear all :
               The doc spec write as below ,
                   Frequency         Emission Level
                2Mhz to 50Mhz    -30dbm/200khz
             1. what's it mean ?
             2. How should I do when I measure spurious use Spectrum Analyzer ?
            (ex: set RBW=200khz  and measured spurious below -30dbm is pass ?
                   or others )
              Thanks.
发表于 2009-5-22 23:15:35 | 显示全部楼层
You got it
 楼主| 发表于 2009-5-24 20:04:49 | 显示全部楼层
Dear sir :
           Thanks your reply.
          To confirm again ,
          1. It means when I measure use Spectrum Analyser I need to set RBW=200Khz start=2.5Mhz stop=100Mhz,
             if measured power level >-30dBm then it's fail , <-30dBm it's pass.
              Right ?
          2. But my boss tell me it's need below -70dbm not -30dbm , I don't know why.
             If I transfer it to dbm/hz is -83dmb/hz ,it become more severe than -70dbm and unit also different.
             I don't know which part is wrong ?
           Thanks.
 楼主| 发表于 2009-5-24 20:12:56 | 显示全部楼层
Sorry , it should be start=2Mhz stop=50Mhz
GMT+8, 2025-12-19 01:27 , Processed in 0.023573 second(s), 7 queries , Gzip On, Redis On.
