楼主: xian
清华大学ARM培训教材(免费!!)
发表于 2009-4-22 04:09:40 | 显示全部楼层
Thanks a lot !!!!!!!!!!!!!!!!!!!
发表于 2009-4-23 07:00:34 | 显示全部楼层
这份资料太棒了
发表于 2009-6-29 17:58:48 | 显示全部楼层
顶了再说!
发表于 2009-7-2 12:28:55 | 显示全部楼层
xiexiexiexie
发表于 2009-7-4 23:25:26 | 显示全部楼层
//与硬件有关的定义:数据口用的是P3口,控制口用的是P2口,
//如果不同,可以更改以下定义。
#include "msp430x44x.h"
#define  LCD_CON_DIR    P2DIR
#define  LCD_CON_OUT    P2OUT
#define  LCD_DI         BIT0
#define  LCD_RW         BIT1
#define  LCD_EN         BIT2
#define  LCD_CS1        BIT3
#define  LCD_CS2        BIT6
#define  LCD_RST        BIT7
#define  LCD_DATA_DIR   P3DIR
#define  LCD_DATA_IN    P3IN
#define  LCD_DATA_OUT   P3OUT
#define  LCD_DATA_BIT0  BIT0
#define  LCD_DATA_BIT1  BIT1
#define  LCD_DATA_BIT2  BIT2
#define  LCD_DATA_BIT3  BIT3
#define  LCD_DATA_BIT4  BIT4
#define  LCD_DATA_BIT5  BIT5
#define  LCD_DATA_BIT6  BIT6
#define  LCD_DATA_BIT7  BIT7
//以下为LCD的命令字
#define DISPLAY_ON    0x3F   //显示屏开命令字
#define DISPLAY_OFF   0x3E   //显示屏关命令字
#define SET_SHOW      0xC0   //设定显示起始行命令字
#define SET_X         0xB8   //设定显示行命令字
#define SET_Y         0x40   //设定显示列命令字
#include "LCD_DEFINE.H"
void lcd_init(void)
  LCD_DATA_OUT = 0x00;
  LCD_DATA_DIR = 0xFF;
  LCD_CON_OUT = LCD_CS1+LCD_CS2+LCD_RST;
  LCD_CON_DIR |= LCD_DI+LCD_RW+LCD_EN+LCD_CS1+LCD_CS2+LCD_RST;
  LCD_CON_OUT &= ~LCD_RST;
  _NOP();
  _NOP();
  LCD_CON_OUT |= LCD_EN;
  _NOP();
  _NOP();
  LCD_CON_OUT &= ~LCD_EN;
  _NOP();
  _NOP();
  LCD_CON_OUT |= LCD_RST;
  _NOP();
  _NOP();
void write_command(unsigned char command)
  LCD_CON_OUT |= LCD_CS1 + LCD_CS2;
  LCD_CON_OUT &= ~(LCD_RW + LCD_DI);
  LCD_DATA_OUT = command;
void write_data( unsigned char data, unsigned char CS1, unsigned char CS2 )
  if(CS1) LCD_CON_OUT |= LCD_CS1;
  else LCD_CON_OUT &=~LCD_CS1;
  if(CS2) LCD_CON_OUT |= LCD_CS2;
  else LCD_CON_OUT &=~LCD_CS2;
  LCD_CON_OUT |= LCD_DI;
  LCD_CON_OUT &=~LCD_RW;
  LCD_DATA_OUT  = data;
  LCD_CON_OUT &=~LCD_EN;
void clear_lcd(void)
  unsigned char i,j;
  for(i=0;i<8;i++)
   write_command(SET_X|i);
   write_command(SET_Y);
   for(j=0;j<128;j++)
    if(j<=63)write_data(0,1,0);
    else write_data(0,0,1);
    _NOP();
void display( unsigned char *chr, unsigned char nRow, unsigned char nCol,
                 unsigned char highth,unsigned char wideth )
//*chr 显示数据的地址,nRow 在显示屏上第几行,nCol 在显示屏上第几列
//highth  字体的高度,wideth 字体的宽度
//128*64有8行,128列
  unsigned char i,tmpCol,tmpRow,h,m;
  unsigned int j;
  tmpRow = nRow;
  m=0;
  for(h=0;h<highth;h=h+8)
    write_command(SET_X|tmpRow);
    tmpCol=nCol;
    for(i=0;i<wideth;i++)
      if(tmpCol<64)
      {write_command(SET_Y|tmpCol);write_data(chr[i+j],1,0);}
      else
      {write_command(SET_Y|(tmpCol-64));write_data(chr[i+j],0,1);}
      tmpCol++;
    m++;
    j=m*wideth;
    tmpRow++;
发表于 2009-11-11 12:57:05 | 显示全部楼层
谢谢分享!
发表于 2009-11-23 12:44:47 | 显示全部楼层
好东西,谢谢楼主
发表于 2009-11-23 20:21:56 | 显示全部楼层
下了,谢谢!
发表于 2009-11-23 20:24:34 | 显示全部楼层
不是免费吗?
发表于 2009-11-27 13:36:11 | 显示全部楼层
A good tutorial
GMT+8, 2025-12-29 05:02 , Processed in 0.022380 second(s), 5 queries , Gzip On, Redis On.
