查看: 4881|回复: 11
NC-$IM l1C (C@dence) 有几个新的Feature
发表于 2009-5-16 08:10:58 | 显示全部楼层 |阅读模式
FEATURE Cadence_Chip_IO_Planner cdslmd 15.0 permanent uncounted BC6DE54D0389360B0B6A \
VENDOR_STRING=S HOSTID=ANY ck=47
[ 本帖最后由 tmd007 于 2009-5-16 08:20 编辑 ]
Nc-Verilog (Cadence License).rar
6.14 KB, 下载次数: 52 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-5-16 08:12:26 | 显示全部楼层
发个全套的cadence的最想念license吧
 楼主| 发表于 2009-5-16 08:14:52 | 显示全部楼层
#  * Install notes follow, License info are below *
#   - Edit this license file and replace the "flexserver" field below with your computer hostname
#   - Create 2 environment variables:          a) LM_LICENSE_FILE
#                                              b) CDS_LIC_FILE
#     assign to both variable this value =>    [email=5280@%7Byour]5280@{your[/email] host name}
#     note under win9x, use autoexec.bat (SET [email=LM_LICENSE_FILE=5280@%7Byour]LM_LICENSE_FILE=5280@{your[/email] host name})
#   - Install any Cadence Licence Manager from any cadence cdroms (ie LDV, PSD)
#   all the next operations suit the PSD installation.
#   - Feed the CD1, run setup.exe if your autorun feature is disabled
#   - Select Network Install ( don't care about any ANTI VIRUS sill NagBox )
#   - Select License Manager Install and point this license file when prompted about a licens file
#   - Ignore the msg about the license can't be parsed, this msg is fake , the license manager is already
#     running perfectly ( poor cadence coders ;D )
#   - Once this License Manager installation is done, just select Install Products
#   - In the license prompt dialog enter 5280 as port number and {your host name} as host name
#     let other text fields as they are (empty)
#   - Now just select all products you need from the list
#   - Insert the cd2 when prompted
#   - If you installed ConceptHDL schemtic entry editor, u may install the librairies from the cd3
#     and if u don't wanna use concept HDL at all, u just burnt a cd for nothing, , isn't that funny!
#   Last step, if the software ask you about a reboot, u should really reboot!
 楼主| 发表于 2009-5-16 08:18:43 | 显示全部楼层
我也想发一个全的,可是需要时间整理啊。
jiancongwoo 发的这个就比较全了,http://www.eetop.cn/bbs/thread-168665-1-3.html
除了我指出的几个缺的Feature,还有可能就是我发的这个里面的几个Feature没有了。
发表于 2009-5-28 04:59:12 | 显示全部楼层
dingyige !!!
发表于 2009-5-28 13:49:26 | 显示全部楼层
这个得留着备用
发表于 2009-6-6 22:41:41 | 显示全部楼层
너무너무 고맙다
너무너무 고맙다
发表于 2009-8-15 14:11:59 | 显示全部楼层
xie xie !!
发表于 2009-9-12 15:56:02 | 显示全部楼层
回复回复
发表于 2009-9-13 15:03:46 | 显示全部楼层
Thanks
GMT+8, 2025-12-31 00:41 , Processed in 0.027280 second(s), 8 queries , Gzip On, Redis On.
