查看: 3101|回复: 6
VCO频率
发表于 2009-4-27 21:31:41 | 显示全部楼层 |阅读模式
实际做PLL时,当VCTRL=0,需把VCO的频率做到很小,不知道你们一般做成多大?我这边做到5M都难啊!
 楼主| 发表于 2009-4-27 22:37:40 | 显示全部楼层
RE
怎么没人来解答啊?
发表于 2009-5-29 05:44:27 | 显示全部楼层
You need to provide more details before you ask.
发表于 2009-10-20 22:35:57 | 显示全部楼层
你是自己设计的VCO吗?
发表于 2009-10-22 15:49:03 | 显示全部楼层
ft only ft...
发表于 2009-10-23 18:40:42 | 显示全部楼层
Usually we get 100-500MHz from a ring oscillator. So you need to put a divider to get 5MHz.
发表于 2009-11-18 10:46:50 | 显示全部楼层
yes, this is the right way for cover 100MHz~500MHz
if you design just like low MHz, also can not get the low freq like 5MHz (if you only get 5M~20M, it can do, but PLL not need!)
the freq tuning range is limited, always 3~5 for Ring OSC, 1%~50% for LC vco
GMT+8, 2025-12-20 08:18 , Processed in 0.019455 second(s), 5 queries , Gzip On, Redis On.
