查看: 13656|回复: 59
【推荐】【Springer 2009 新书首发】Jan Rabaey 的 Low Power Design Essentials
发表于 2009-4-26 17:50:34 | 显示全部楼层 |阅读模式
原帖地址
http://www.eetop.cn/bbs/viewthread.php?tid=164396&extra=page%3D1%26amp%3Bfilter%3D0%26amp%3Borderby%3Ddateline%26amp%3Bascdesc%3DDESC
Low Power Design Essentials (Integrated Circuits and Systems)
By Jan Rabaey
Publisher:   Springer
Number Of Pages:   288
Publication Date:   2009-04-13
ISBN-10 / ASIN:   0387717129
ISBN-13 / EAN:   9780387717128
Product Description:
Low Power Design Essentials contains all the topics of importance to the low power designer. The book lays the foundation with background chapters entitled “Advanced MOS Transistors and Their Models” and “Power Basics”. These chapters are followed by chapters on the design process including: optimization, architecture and algorithm level, memory, run time, standby logic, and standby memory. Chapters on special topics are also included: power management and modal design, ultra low power, and low power design methodology and flows. The book concludes with a chapter on case studies as well as a chapter on “Projection into the Future”.
These chapters are all based on the extensive amount of teaching that the author has carried out both at universities and companies worldwide. All chapters have been drawn up specifically for self-study. They aim, however, at different levels of understanding. All the chapters start with elementary material, but most also contain advanced material. A new format is used for this book. All slides are included on a CD-ROM, as PDF files and are reproduced in the book, followed by the comments normally given by the teacher. This is advantageous in that the material used for teaching is also the material used by the student, and that only one additional aspect is explained per slide. The student can therefore easily monitor their progress. It is hoped that this new format provides a better structure in both teaching and studying these essential topics.
Springer 数据库的原版eBook,全彩图,更难得的是连图片也是vector quality的,所以39MB的书可以压缩得只有20MB,Cheers~~~~~
[ 本帖最后由 tjumicrosoft 于 2009-4-26 17:52 编辑 ]
发表于 2009-4-26 21:45:19 | 显示全部楼层
哪里可以买?
发表于 2009-5-23 13:28:56 | 显示全部楼层
good book
发表于 2009-5-23 23:13:18 | 显示全部楼层
good
发表于 2009-5-24 00:59:06 | 显示全部楼层
thanks for sharing!!
发表于 2009-5-24 01:00:09 | 显示全部楼层
Thanks for sharing
发表于 2009-7-15 21:10:59 | 显示全部楼层
fu hue
duox ie
发表于 2009-7-15 21:18:05 | 显示全部楼层
很好
多谢哈,很好
发表于 2009-7-15 22:41:15 | 显示全部楼层
thanks!
发表于 2009-7-15 23:10:24 | 显示全部楼层
:victory: :victory:
GMT+8, 2025-11-1 03:48 , Processed in 0.024875 second(s), 5 queries , Gzip On, Redis On.
