查看: 2349|回复: 2
求助: armgcc编译问题
发表于 2005-7-24 21:53:45 | 显示全部楼层 |阅读模式
文件:EINTDEMO.CPP
void EXTint_FIQ (void) __attribute__ ((interrupt("FIQ")));
void EXTint_FIQ(void)
文件:STARTUP.S
        .text
        .arm
        .global EXTint_FIQ /*在EINTDEMO.CPP定义的FIQ函数*/
        .global _startup
        .func   _startup
_startup:
# Exception Vectors
#  Mapped to Address 0.
#  Absolute addressing mode must be used.
#  Dummy Handlers are implemented as infinite loops which can be modified.
Vectors:        LDR     PC, Reset_Addr
                LDR     PC, Undef_Addr
                LDR     PC, SWI_Addr
                LDR     PC, PAbt_Addr
                LDR     PC, DAbt_Addr
                NOP                            /* Reserved Vector */
#               LDR     PC, IRQ_Addr
                LDR     PC, [PC, #-0x0FF0]     /* Vector from VicVectAddr */
                LDR     PC, FIQ_Addr
Reset_Addr:     .word   Reset_Handler
Undef_Addr:     .word   Undef_Handler
SWI_Addr:       .word   SWI_Handler
PAbt_Addr:      .word   PAbt_Handler
DAbt_Addr:      .word   DAbt_Handler
                .word   0                      /* Reserved Address */
IRQ_Addr:       .word   IRQ_Handler
FIQ_Addr:       .word   EXTint_FIQ /*执行EINTDEMO.CPP中的函数EXTint_FIQ()*/
编译结果分别单个编译都各自通过,和在一起编译出错)
startup.o(.text+0x3c):/cygdrive/c/GCCARM/democpp/Startup.s:232: undefined reference to `EXTint_FIQ'
collect2: ld returned 1 exit status
Target not created
不知如何解决...谢谢!!!
 楼主| 发表于 2005-7-24 22:38:24 | 显示全部楼层
求助: armgcc编译问题
请问站长,本人首次发帖,为何不许回复???
不解???!!!
发表于 2012-10-28 14:31:29 | 显示全部楼层
bu dong yan jiu yan jiu
GMT+8, 2025-10-17 21:33 , Processed in 0.016280 second(s), 5 queries , Gzip On, Redis On.
