查看: 4176|回复: 8
ECE547Report_12-bit Digital to Analog Converter
发表于 2009-4-24 09:53:31 | 显示全部楼层 |阅读模式
ECE547Report_12-bit Digital to Analog Converter.pdf
1.03 MB, 下载次数: 184 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-4-24 09:55:55 | 显示全部楼层
thanks
发表于 2009-4-24 10:10:17 | 显示全部楼层
A CMOS design of a 12-bit DAC for the AMI C5N process. Simulation results show the design can
operates on a 4MHz clock and can produce a 1.6Vpp output sine wave up to 2MHz centered at 2.2V. The
chip is a dual packaged DAC, with isolated opamp and resistor segment (for testing purposes). The DAC
accepts a 0-5V 12-bit digital input signal in binary format. The DAC topology is a Wide-Swing Current-
Mode Segmented R-2R with a R=40k
. The design has a maximum capacitive load of 50pF in parallel
with a minimum resistive load of 500
. Spectral analysis of the simulation output shows the fundamental
signal strength of a 250KHz signal to be approximately 70dB higher than the nearest overtone.
发表于 2012-9-22 01:50:04 | 显示全部楼层
good as a reference...............
发表于 2014-9-11 01:34:00 | 显示全部楼层
fgdgdfgdfgfdgfdgdf
发表于 2017-12-11 21:06:19 | 显示全部楼层
great !!!
发表于 2022-6-25 11:12:14 | 显示全部楼层
学习
发表于 2023-2-21 16:57:34 | 显示全部楼层
正好要做一个12bit DAC,太好了,学习下
发表于 2023-2-22 01:55:41 | 显示全部楼层
感谢分享
GMT+8, 2025-12-22 05:40 , Processed in 0.025225 second(s), 5 queries , Gzip On, Redis On.
