查看: 5985|回复: 2
斑竹帮忙看一下我的iic驱动,根据demo改写,scl和sda一直保持为高。
发表于 2005-7-16 22:22:00 | 显示全部楼层 |阅读模式
问题:
当调用写函数的时候,根本没有中断产生,但是请求中断是成功的。
不知道是那里的原因。请大家帮我看一下。
#include <linux/config.h>
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/init.h>
#include <asm/io.h>
#include <linux/miscdevice.h>
#include <linux/sched.h>
#include <linux/delay.h>
#include <linux/poll.h>
#include <linux/spinlock.h>
#include <linux/irq.h>
#include <asm/arch/irqs.h>
#include <asm/delay.h>
#include <asm/arch/S3C2410.h>
#include <asm/hardware.h>
#define DEVICE_NAME "IIC"
#define IIC_MAJOR 233
#define IICBUFSIZE 20
#define IICCON  __REG2(0x54000000,4)
#define IICSTAT __REG2(0x54000004,4)
#define IICADD  __REG2(0x54000008,4)
#define IICDS   __REG2(0x5400000c,4)
#define WRDATA      (1)
#define POLLACK     (2)
#define RDDATA      (3)
#define SETRDADDR   (4)
#define BIT_IIC (0x1<<27)
#define IOCTL_SLAVE_ADDR  1
static DECLARE_WAIT_QUEUE_HEAD(iic_wait);
static char iic_Data[IICBUFSIZE];
static volatile int iic_DataCount;
static volatile int iic_Mode;
static volatile int iic_Status;
static int iic_Pt;
static unsigned int old_gpecon,old_gpeup;      //use to save GPECON GPEUP
static int slave_addr=0xA0;
static void iic_port_init(void)
old_gpecon   = GPECON;
old_gpeup  = GPEUP;
printk("IIC INIT\nIICON=%x, IICSTAT=%x\n",IICCON,IICSTAT);
    GPEUP  |= 0xc000;                  //Pull-up disable
    GPECON |= 0xa0000000;                //GPE15:IICSDA , GPE14:IICSCL
INTMSK &= ~(BIT_IIC);
IICCON = (1<<7) | (0<<6) | (1<<5) | (0xf);
IICADD  = 0x10;                    //2410 slave address = [7:1]
IICSTAT = 0x10;                    //IIC bus data output enable(Rx/Tx)
static void iic_irq(int irq, void *dev_id, struct pt_regs *reg)
    int iicSt,i;
    printk("IIC IRQ\n");
    SRCPND = BIT_IIC;          //Clear pending bit
    INTPND = BIT_IIC;
    iicSt   =IICSTAT;
    if(iicSt & 0x8){}           //When bus arbitration is failed.
    if(iicSt & 0x4){}           //When a slave address is matched with IICADD
    if(iicSt & 0x2){}           //When a slave address is 0000000b
    if(iicSt & 0x1){}           //When ACK isn't received
    switch(iic_Mode)
       case POLLACK:
           iic_Status = iicSt;
           break;
        case WRDATA:
            if((iic_DataCount--)==0)
                IICSTAT = 0xd0;                //Stop MasTx condition
                IICCON  = 0xaf;                //Resumes IIC operation.
                udelay(1);                       //Wait until stop condtion is in effect.
                       //The pending bit will not be set after issuing stop condition.
                break;
            IICDS = iic_Data[iic_Pt++];        //iic_Data[0] has dummy.
            for(i=0;i<10;i++);                  //for setup time until rising edge of IICSCL
            IICCON = 0xaf;                     //resumes IIC operation.
            break;
        default:
            break;
static int iic_write(struct file * file,const char * buffer, size_t count, loff_t *ppos)
printk("IIC WRITE\n");
iic_Mode      = WRDATA;
     iic_Pt        = 1;
iic_DataCount = count-1;
     copy_from_user(iic_Data,buffer,count);
     IICDS   = iic_Data[0];
     IICSTAT = 0xf0;                    //MasTx,Start
       //Clearing the pending bit isn't needed because the pending bit has been cleared.
printk("ready to cycle\n");
     while(iic_DataCount!=-1)
  printk("IICCON=%x,IICSTAT=%x\n",IICCON,IICSTAT);
     iic_Mode = POLLACK;
     while(1)
         iic_Status = 0x100;
         while(iic_Status==0x100);
         if(!(iic_Status&0x1))
          break;                      //When ACK is received
        //Write is completed
return 0;
static int iic_open(struct inode *inode, struct file *file)
iic_port_init();
return 0;
static struct file_operations iic_fops =
owner: THIS_MODULE,
read: iic_read,
write: iic_write,
open: iic_open,
static devfs_handle_t devfs_handle;
static int __init iic_init(void)
int ret;
ret = register_chrdev(IIC_MAJOR, DEVICE_NAME, &iic_fops);
if (ret < 0) {
   printk(DEVICE_NAME " can't register major number\n");
   return ret;
set_external_irq(IRQ_IIC, EXT_FALLING_EDGE, GPIO_PULLUP_DIS);
ret = request_irq(IRQ_IIC, &iic_irq, SA_INTERRUPT, DEVICE_NAME, &iic_irq);
if (ret<0)
  unregister_chrdev(IIC_MAJOR, DEVICE_NAME);
  printk(DEVICE_NAME " can't request irq %d\n", IRQ_IIC);
  return ret;
printk("request IIC IRQ success\n");
devfs_handle = devfs_register(NULL, DEVICE_NAME, DEVFS_FL_DEFAULT,IIC_MAJOR, 0, S_IFCHR | S_IRUSR | S_IWUSR,&iic_fops, NULL);
iic_port_init();
return 0;
static void __exit iic_exit(void)
INTMSK |= BIT_IIC;
        GPEUP  = old_gpeup;
        GPECON = old_gpecon;
devfs_unregister(devfs_handle);
free_irq(IRQ_IIC, iic_irq);
module_init(iic_init);
module_exit(iic_exit);
发表于 2005-7-19 09:22:19 | 显示全部楼层
不懂啊
发表于 2007-4-27 13:16:27 | 显示全部楼层
您的DEMO 是那里的IIC驱动啊?
能给我一份DMEO 么?
sasinop@hotmail.com
GMT+8, 2025-12-21 08:00 , Processed in 0.019186 second(s), 6 queries , Gzip On, Redis On.
