楼主: william6898
hspices 和hspiced有什么区别?
发表于 2014-10-23 15:33:52 | 显示全部楼层
学习中啊
发表于 2015-7-1 14:23:01 | 显示全部楼层
三楼,高手,赞一个
发表于 2016-10-1 20:48:13 | 显示全部楼层
学习了,
发表于 2017-1-17 09:15:46 | 显示全部楼层
hspiceS - Hspice with soket interface
hspiceD - Hspice with direct interface
From Analog Circuit Design Environment User Guide
"Cadence has integrated simulators into the analog circuit design environment in two ways:
Interfaces that use the direct simulation approach
This is the preferred approach. With direct simulation, the netlist uses the syntax of the simulator you are using, without any processing to evaluate expressions. The passed parameters, design variables, functions, and so on are all resolved by the simulator. The netlist is a direct reflection of the design.
Interfaces that use cdsSpice for processing of the netlist
With socket interfaces, the netlist is processed by Cadence SPICE to evaluate all expressions and resolve passed parameters. You would use the socket methodology to integrate your simulator if the simulator you use cannot handle expressions or parameter passing."
发表于 2017-9-7 17:22:55 | 显示全部楼层
学习了。。。
发表于 2019-7-14 14:57:48 | 显示全部楼层
武也锋 发表于 2013-1-21 14:44
我用HspiceD仿真时,仿真显示成功了··但是没有波形出来···各位大侠  这是为什么呢? ...
找到原因了吗?我也出现这个问题。
发表于 2019-12-13 19:01:58 | 显示全部楼层
学习了
发表于 2021-2-8 15:43:26 | 显示全部楼层
顶三楼,学习了
GMT+8, 2025-12-22 06:12 , Processed in 0.020161 second(s), 4 queries , Gzip On, Redis On.
