楼主: lds121
ise tcad 7.0 下载与安装xp版本
发表于 2009-9-28 21:58:43 | 显示全部楼层
ISE TCAD7.0_setup.part001.rar18
发表于 2009-9-28 22:00:43 | 显示全部楼层
发表于 2009-9-28 22:02:02 | 显示全部楼层
发表于 2009-9-28 22:10:30 | 显示全部楼层
上传完毕。
安装说明:
Installation Instructions:
1)
Daemon F:\ISE_TCAD_70\ISE_installation\tfl-tcad.cue
2)
Install Cygwin for WinNT (in cygwin folder, run setup.exe)
3)
Install ISE TCAD 7.0 (setup.exe in root folder)
4)
Copy license.dat file to C:\ISE\licenses directory
5)
Edit license.dat to your hostname
6)
Check / Create Environment Variables
a.
ISEROOT
C:\ISE
b.
ISERELEASE
7.0
c.
TMP
C:\TMP
d.
TEMP
C:\TEMP
e.
ISEDB
C:\DATAFILES\MYISEDATA
f.
DISPLAY
HOSTNAME:0.0
g.
TEC80HOME
C:\ISE\TEC80
h.
FP_NO_HOST_CHECK
NO
i.
系统变量中在变量Path的已有“;%TEC80HOME%\BIN;C:\ISE\bin”
7)
WinNT License Daemon
a.
Open lmtools.exe from the \ISE\bin directory
b.
Click “Configuration using Services” box
c.
Choose “Configure Services” tab
d.
Type a name for the “Service Name” (ex. ISETCAD)
e.
Fill in the “Path to the lmgrd.exe file” with C:\ISE\tcad\7.0\ix86\WinNT\etc\lmgrd.exe or the path you installed the software.
f.
Fill in the “Path to the license file” with C:\ISE\licenses\license.dat or the path you installed the software
g.
Fill in the “Path to the debug log file” with C:\ISE\licenses\license.log or the path you installed the software
h.
Click on the “Start Server at Power Up” and “Use Services” box
i.
Click “Save Service” button
j.
Choose “Start/Stop/Reread” tab
k.
Click “Start Server” button
l.
Close lmtools.exe
8)
Install a PC X-Server (Exceed)
发表于 2009-9-28 22:12:06 | 显示全部楼层
上传完毕。
安装说明:
1)
2)
3)
4)
5)
6)
a.
ISEROOT
C:\ISE
b.
ISERELEASE
7.0
c.
TMP
C:\TMP
d.
TEMP
C:\TEMP
e.
ISEDB
f.
DISPLAY
HOSTNAME:0.0
g.
TEC80HOME
C:\ISE\TEC80
h.
FP_NO_HOST_CHECK
NO
i.
7)
a.
b.
c.
d.
e.
f.
g.
h.
i.
j.
k.
l.
Close lmtools.exe
8)
发表于 2009-9-29 21:46:12 | 显示全部楼层
dingdingdingding
发表于 2009-10-25 22:37:35 | 显示全部楼层
ise tcad 7.0
发表于 2009-11-11 00:07:10 | 显示全部楼层
能装不
发表于 2009-11-25 09:37:39 | 显示全部楼层
找了好久啦 多谢
头像被屏蔽
发表于 2009-11-25 09:39:10 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-12-17 14:50 , Processed in 0.019700 second(s), 5 queries , Gzip On, Redis On.
