查看: 13127|回复: 22
ise tcad 7.0 下载与安装
发表于 2009-4-17 08:19:27 | 显示全部楼层 |阅读模式
安装说明:
Installation Instructions:
1)
Daemon F:\ISE_TCAD_70\ISE_installation\tfl-tcad.cue
2)
Install Cygwin for WinNT (in cygwin folder, run setup.exe)
3)
Install ISE TCAD 7.0 (setup.exe in root folder)
4)
Copy license.dat file to C:\ISE\licenses directory
5)
Edit license.dat to your hostname
6)
Check / Create Environment Variables
a.
ISEROOT
C:\ISE
b.
ISERELEASE
7.0
c.
TMP
C:\TMP
d.
TEMP
C:\TEMP
e.
ISEDB
C:\DATAFILES\MYISEDATA
f.
DISPLAY
HOSTNAME:0.0
g.
TEC80HOME
C:\ISE\TEC80
h.
FP_NO_HOST_CHECK
NO
i.
系统变量中在变量Path的已有“;%TEC80HOME%\BIN;C:\ISE\bin”
7)
WinNT License Daemon
a.
Open lmtools.exe from the \ISE\bin directory
b.
Click “Configuration using Services” box
c.
Choose “Configure Services” tab
d.
Type a name for the “Service Name” (ex. ISETCAD)
e.
Fill in the “Path to the lmgrd.exe file” with C:\ISE\tcad\7.0\ix86\WinNT\etc\lmgrd.exe or the path you installed the software.
f.
Fill in the “Path to the license file” with C:\ISE\licenses\license.dat or the path you installed the software
g.
Fill in the “Path to the debug log file” with C:\ISE\licenses\license.log or the path you installed the software
h.
Click on the “Start Server at Power Up” and “Use Services” box
i.
Click “Save Service” button
j.
Choose “Start/Stop/Reread” tab
k.
Click “Start Server” button
l.
Close lmtools.exe
8)
Install a PC X-Server (Exceed)
 楼主| 发表于 2009-4-17 08:20:58 | 显示全部楼层
错了
请到eda资源下载区下载。
 楼主| 发表于 2009-4-18 07:59:53 | 显示全部楼层
ffffffffffffffffffffffffffs
顶一下。。。。。。。。。。。。。。
发表于 2009-9-10 21:18:39 | 显示全部楼层
谢谢
谢谢谢谢谢谢谢谢谢谢谢谢
发表于 2010-2-18 21:32:00 | 显示全部楼层
ding     mmmmmmmmm
发表于 2010-3-2 11:12:17 | 显示全部楼层
谢谢,很有用
发表于 2010-4-12 18:47:46 | 显示全部楼层
Thanks for useful instructions! I'm downloading now TCADv7!
发表于 2010-4-23 16:51:00 | 显示全部楼层
发表于 2010-4-23 18:19:35 | 显示全部楼层
发表于 2010-6-15 09:23:35 | 显示全部楼层
好东西!谢谢分享。
GMT+8, 2025-12-21 03:46 , Processed in 0.026309 second(s), 7 queries , Gzip On, Redis On.
