查看: 2827|回复: 8
Output Load Resistance是什么东东?
发表于 2009-4-14 22:47:38 | 显示全部楼层 |阅读模式
RT 搞了好久没搞清楚,不是输出阻抗的意思哦
 楼主| 发表于 2009-4-20 20:18:30 | 显示全部楼层
我等的高手还不来....
发表于 2009-4-23 16:26:33 | 显示全部楼层
输出负载阻抗
 楼主| 发表于 2009-4-23 22:06:24 | 显示全部楼层
老大,给点详细的解释!
发表于 2009-4-28 12:41:58 | 显示全部楼层
直接翻译是输出负载阻抗,应该就是负载阻抗
发表于 2009-5-15 12:00:51 | 显示全部楼层
Look at circuit from output, the resistance you can "see" is Output Load Resistance; similary, look at circuit from input, the resistance you can "see" is Input Source Resistance. Bear in mind, these Resistance maybe not be the value of actual resistor at the load/souce, but the comibiation of several components and next stage IC.
发表于 2009-5-17 17:19:31 | 显示全部楼层
最好把你碰到问题的环境也描述一下
发表于 2009-5-17 20:10:12 | 显示全部楼层
可能只能带阻性负载,才有输出负载阻抗说法。
发表于 2009-5-22 22:11:20 | 显示全部楼层
输出负载阻抗,就是你的输出端所外接的阻抗
GMT+8, 2025-12-22 00:31 , Processed in 0.017225 second(s), 3 queries , Gzip On, Redis On.
