查看: 2872|回复: 2
各位大侠,什么是ARM MultiICE ,ARM MultiTrace啊?非常感谢!
发表于 2005-5-24 16:55:18 | 显示全部楼层 |阅读模式
[这个贴子最后由beijiguxin在 2005/05/24 04:56pm 第 1 次编辑]
 楼主| 发表于 2005-5-24 17:38:37 | 显示全部楼层
唉,看来还得靠自己,ARM MultiICE is the embeddedICE logic debug solution from ARM.It enables you to debug software running on ARM processor cores that include the EmbeddedICE logic. ARM MultiTrace unit works in conjunction with the ARM Multi-ICE to provide RealTrace functionality for software running in leading edge System-on-chip(SOC)devices with deeply embedded processor cores,
发表于 2005-6-15 01:14:21 | 显示全部楼层
你可以把帖子名字改了
GMT+8, 2025-12-28 11:33 , Processed in 0.018522 second(s), 7 queries , Gzip On, Redis On.
