楼主: michaeleguo2
Quartus II 9.0 Linux Crack
发表于 2009-6-17 09:58:12 | 显示全部楼层
Thanks
发表于 2009-6-21 19:45:22 | 显示全部楼层
太好了!收下啦!
发表于 2009-6-23 10:00:27 | 显示全部楼层
手工破解
cd <quartus_install_dir>/linux
cp libsys_cpt.so libsys_cpt.so.bak
then run gdb:
gdb> file libsys_cpt.so
gdb> info function l_pubkey_verify
Note the resulting address (for Quartus 7.2 it was 0x000c617b)
quit gdb, then open libsys_cpt.so using a hex editor, then go to the address
that you got from gdb and replace the 3 bytes starting at that address with
those bytes: 31 C0 C3
Alternatively one can get the address of 'l_pubkey_verify' function using the
command:
nm libsys_cpt.so | grep l_pubkey_verify
Now regular quartus tool flow can work, except for the Design Space Explorer,
to get the Design Space Explorer working do the following:
* Note the first few bytes (8 or more) in the 'l_pubkey_verify' function of the
original libsys_cpt.so, and search for those bytes in quartus_sh (using a hex
editor). I found that the number of bytes to search for (which were 8 for
Quartus 8.0) are the minimum number of bytes which will match only once in
quartus_sh.
* Replace the first 3 bytes with those bytes: 31 C0 C3
发表于 2009-6-23 11:07:19 | 显示全部楼层
收藏了,谢谢!
发表于 2009-6-24 08:39:04 | 显示全部楼层
Thanks a lot!
As said, Thank you!
发表于 2009-6-25 09:59:50 | 显示全部楼层
我收下了。。看看
发表于 2009-7-3 13:32:31 | 显示全部楼层
谢谢,正需要这个呢。
发表于 2009-7-12 08:15:57 | 显示全部楼层
需要这个
刚装了,以为是网络版本的。结果不是。
楼主既然是linux的,为何用zip。怀疑真实性。说明也不详细。
发表于 2009-7-18 12:32:42 | 显示全部楼层
可是在linux下怎样破解呢?替换了那个文件后还是不是破解的。。。。。
发表于 2009-8-12 14:53:54 | 显示全部楼层
资产不够了,发个帖顶一下,谢谢楼主
GMT+8, 2025-9-11 14:34 , Processed in 0.029297 second(s), 4 queries , Gzip On, Redis On.
