查看: 1370|回复: 2
A 1.5V 10-b 30-MS/s CMOS Pipelined
发表于 2009-4-2 09:59:10 | 显示全部楼层 |阅读模式
Analog-to-Digital Converter
0493.pdf
400.37 KB, 下载次数: 22 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-10-20 12:08:51 | 显示全部楼层
好东西
发表于 2011-10-20 12:28:12 | 显示全部楼层
Circuits IEEE International Symposium on and Systems, 2007.
ISCAS 2007 Paper
Abstract:
A 10-b 30-MS/s low power CMOS pipelined analog-to-digital converter (ADC) is described. A low-voltage technique is proposed for pipelined analog-to-digital converter that avoids the use of on-chip clock voltage doubler, multithreshold voltage process, bootstrapped switch, or switched-opamp technique. At the front-end, a low-voltage S/H circuit with cross-coupled input sampling switch is employed to eliminate the input signal feedthrough and enhance the dynamic performance of the pipelined ADC. The cross-coupled configuration of multiplying digital-to-analog converter (MDAC) also provides an effective common-mode feedback to overcome the problem of common-mode accumulation. This design achieves DNL and INL of 0.38LSB and 0.46LSB respectively, while SNDR is 58.5dB and SFDR is 66.1dB at an input frequency of 12MHz. Operating at 30MS/S sampling rate under a single 1.5V power supply, the power consumption is 36.8mW in a 0.35 mum CMOS process. Simulations have been performed to demonstrate the feasibility of this new technique.
GMT+8, 2025-12-29 00:34 , Processed in 0.015714 second(s), 5 queries , Gzip On, Redis On.
