查看: 2380|回复: 4
High slew rate two stage A AB and AB op-amps
发表于 2009-4-2 09:19:23 | 显示全部楼层 |阅读模式
High slew rate two stage A AB and AB op-amps with phase lead compensation at output node and local common mode feedback
abbr_1334521349186da22965872233adcdfe.pdf
324.79 KB, 下载次数: 152 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-9-18 13:01:04 | 显示全部楼层
thank you very much
发表于 2009-9-18 13:04:09 | 显示全部楼层
thank you very much
发表于 2015-1-9 18:39:29 | 显示全部楼层
好好看看看
发表于 2020-12-7 19:58:33 来自手机 | 显示全部楼层
谢谢楼主啦
GMT+8, 2025-12-29 21:42 , Processed in 0.018367 second(s), 6 queries , Gzip On, Redis On.
