楼主: yangmei
HDL Turbo Writer
发表于 2013-5-31 16:50:55 | 显示全部楼层
Turbo WriterTurbo Writer
发表于 2013-8-27 19:08:27 | 显示全部楼层
Turbo Writer is a high performance HDL syntax directed editor running on the PC under Windows. It enables the semi-automatic generation of both VHDL and Verilog, and offers a fast code development environment on the PC, fully compliant with the IEEE 1076, VITAL and OVI standards. Turbo Writer automatically generates HDL skeleton code - colour coded, line numbered and indented - from a rich set of templates using the first two letters of the HDL Key word followed by . Integration with Model Technology's V-System VHDL/Verilog compiler and simulator allows code to be compiled from within VHDL Turbo Writer, highlighting any errors found - dramatically accelerating the compile-edit turn around time during syntactic debug. HDL Turbo Writer is low priced, with volume discounts to encourage wide adoption. VHDL Turbo Writer features: .Automatic line numbering .Automatic indentation .Automatic colour coding .Rich set of VHDL and Verilog coding templates .Multiple template styles .Automatic Testbench generation .Automatic Component declarations Fully integrated with Model Technology: .Compile from within the editor .Error lines highlighted in edit window .Fast compile/edit loop Fully integrated with Renior .Renoir calls Turbo Writer to view HDL code. .Turbo Writer calls Renoir to locate the source diagram for HDL generated code. Fully featured Windows based text editor: .Multi-window/multi-document edit .Copy between documents .Unimited undo/redo .Search and replace across multiple files .File size limited only by PC memory .File folding .Optional Brief and VI emulation System Requirements: Microsoft Windows 95/NT IBM PC or compatible 16 Mb memory
发表于 2013-12-6 22:22:14 | 显示全部楼层
听说很厉害啊。。试试
发表于 2014-4-26 17:45:33 | 显示全部楼层
好用不好用?
发表于 2014-10-30 10:50:43 | 显示全部楼层
谢谢分享
发表于 2020-6-23 21:42:34 | 显示全部楼层
曾经的神奇啊,上古时期的了
GMT+8, 2025-12-17 07:41 , Processed in 0.013791 second(s), 2 queries , Gzip On, Redis On.
