查看: 2898|回复: 1
Potential antenna designs for a wearable antenna at 440 MHz
发表于 2009-3-22 22:17:38 | 显示全部楼层 |阅读模式
The planar inverted –F antenna is popular for portable wireless devices because of its low profile, small size, and built-in structure [1]. The other major advantages are easy fabrication, low manufacturing cost, and simple structure [2]. Also, PIFA’s inherent bandwidth is higher than the bandwidth of the conventional patch antenna (since a thick air substrate is used).
The basic PIFA (a “grounded” patch antenna - l/4 patch length instead of the conventional l/2) consists of a ground plane, a top plate element, a feed wire feeding the resonating top plate, and a DC-shorting plate that is connecting the ground and the top plate at one end of the resonating patch.
basic_pifa.zip
621.35 KB, 下载次数: 26 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-3-23 21:02:52 | 显示全部楼层
good book
:lol :lol :lol :lol :lol
GMT+8, 2025-12-26 20:27 , Processed in 0.919478 second(s), 4 queries , Gzip On, Redis On.
