查看: 4148|回复: 7
sigma-delta ADC 运放的问题
发表于 2009-3-16 18:07:41 | 显示全部楼层 |阅读模式
四阶的sigam-delta modulator,第一级运放1/f噪声仿出来是-40db,好像太高. 差分输入尺寸已经很大了,280um^2,低功耗共8uA的电流。没看到讨论调制器运放噪声的资料,噪声方面有啥要求,望有经验者回答
发表于 2009-3-16 18:10:04 | 显示全部楼层
噪声要求高的话,管子可以继续加大的
或者试试CDS 或者 choper stablization
 楼主| 发表于 2009-3-16 18:10:13 | 显示全部楼层
补充一下,做低频带宽1K,考虑1/f噪声
发表于 2009-3-17 00:31:16 | 显示全部楼层
switched-cap 的,就试试cds或者chop
continuous-time的,就用chop
去1/f很简单的
发表于 2009-3-17 07:37:36 | 显示全部楼层
Your SDM must be used in audio type application. For such an applicaiton, 1/f is very critical, 280um^2 is not regarded big.  However, what is your L and W, W/L=140u/2u and W/L=70u/4u will give you different results. Try to keep WL=const and optimized see if 1/f dominates at the first stage or its loading stage.  Using chopper/CDS of course, is another solution, however, you must be careful. They will be some side-effected and constrained to use.
 楼主| 发表于 2009-3-17 12:02:45 | 显示全部楼层
现在可以到-90db以下,再加choper应该就可以了吧
发表于 2009-3-17 12:56:03 | 显示全部楼层
受教了,谢谢牛人
发表于 2020-3-23 14:52:42 | 显示全部楼层
good answer ~!!
GMT+8, 2025-12-14 07:31 , Processed in 0.019356 second(s), 5 queries , Gzip On, Redis On.
