查看: 8795|回复: 6
请问spectre的命令行模式有没有入门的文档?
发表于 2009-3-12 08:48:34 | 显示全部楼层 |阅读模式
网上搜了蛮久,基本都找不到相关的信息
想把spectre的图形化操作简化还原为命令行,然后设计个批处理的程序来快速仿真和简化流程
不知道有没有高人曾经做过,有的话,能否指点迷津,谢谢!!
发表于 2012-4-13 09:13:31 | 显示全部楼层
As for Cadence Spectre Circuit Simulator, there are many ways to do the non-graphic model;
--> 1. Use the OCEAN; You can find the OCEAN manual just google it;
--> 2. Use the Spectre; Before that you need to set the ENV and the Lib files and the Cadence Licences.
--> 3. You can use SKILL script; Just google Candence SKILL User Guide;
发表于 2012-4-13 09:14:48 | 显示全部楼层
Here is a Link:
http://www.engr.uky.edu/~elias/Tutorial_F08/Spectre_Tutorial.htm
发表于 2012-4-13 09:20:34 | 显示全部楼层
http://rfic.eecs.berkeley.edu/142/pdf/spectre_start.pdf
发表于 2015-8-17 15:29:49 | 显示全部楼层
回复 4# vvcoke
    谢谢答复!
发表于 2015-12-9 17:31:42 | 显示全部楼层
发表于 2020-9-9 19:04:34 | 显示全部楼层
谢谢,参考下
GMT+8, 2025-12-22 14:07 , Processed in 0.022035 second(s), 8 queries , Gzip On, Redis On.
