查看: 2315|回复: 0
请教:Quartus 编译警告问题
发表于 2009-3-6 00:09:26 | 显示全部楼层 |阅读模式
Quartus 编译产生如下警告:
Warning: Found pins functioning as undefined clocks and/or memory enables
Info: Assuming node "key2" is an undefined clock
Info: Assuming node "key1" is an undefined clock
其中,key1,key2是INPUT引脚,实际是外接两个按键,不知上面警告是为什么,请高手指点,谢谢!
GMT+8, 2025-12-24 12:40 , Processed in 0.013579 second(s), 5 queries , Gzip On, Redis On.
