查看: 21153|回复: 48
.cshrc转换成.bashrc
发表于 2009-3-4 17:55:36 | 显示全部楼层 |阅读模式
请问在RHEL4下,如果我用Bash shell,在Hspice 的install_dir/hspice/bin/cshrc.meta和kshrc.meta,使用哪一个?还是要将cshrc.meta的内容改成bash的格式?如果要改成bash格式,如何改?谢谢!
cshrc.meta的内容如下:
######### HSPICE Global environment variable Wed Mar  4 17:18:58 CST 2009 #########
# Using FLEXlm license file
setenv installdir /home/EDA/Synopsys/Hspice/hspice
if ( $?LM_LICENSE_FILE ) then
   if (( "$LM_LICENSE_FILE" !~ *"/home/EDA/Synopsys/Hspice/hspice/license.dat"* )&& (-e /home/EDA/Synopsys/Hspice/hspice/license.dat)) then
      setenv LM_LICENSE_FILE /home/EDA/Synopsys/Hspice/hspice/license.datLM_LICENSE_FILE
   endif
else
   if (-e /home/EDA/Synopsys/Hspice/hspice/license.dat) then
   endif
endif
unsetenv LANG
unsetenv LC_ALL
setenv ARCH      `$installdir/bin/get_arch `
setenv HSP_HOME $installdir
set path= ( $HSP_HOME/bin $installdir/$ARCH $HSP_HOME/$ARCH/veriloga_utils/veriloga/include  $path )
######### End of Global section ##########
kshrc.meta内容如下:
######### HSPICE Global environment variable on Wed Mar  4 00:38:35 CST 2009 #########
installdir=/home/EDA/Synopsys/Hspice/hspice
export installdir
ARCH=`$installdir/bin/get_arch `
export ARCH
if [ -z "$LM_LICENSE_FILE" ]
then
   LM_LICENSE_FILE=/home/EDA/Synopsys/Hspice/hspice/license.dat
   export LM_LICENSE_FILE
else
   LM_LICENSE_FILE=/home/EDA/Synopsys/Hspice/hspice/license.datLM_LICENSE_FILE
fi
unset LANG
unset LC_ALL
发表于 2009-3-4 19:15:34 | 显示全部楼层
不用改 直接切换到CSHELL就好了
 楼主| 发表于 2009-3-4 23:56:26 | 显示全部楼层
机子上其他软件的环境变量都是用的Bash shell,所以这个也想用Bash,所以想请教大家,谢谢!
发表于 2009-3-16 15:20:35 | 显示全部楼层
谢谢分享
发表于 2010-2-17 22:18:34 | 显示全部楼层
home/EDA/Synopsys/Hspice/hspice/license.dat@
发表于 2010-2-18 07:45:29 | 显示全部楼层
thanks a lot
发表于 2010-2-18 07:46:31 | 显示全部楼层
thanks a lot
发表于 2010-2-18 07:47:56 | 显示全部楼层
thanks a lot
发表于 2010-2-18 07:49:01 | 显示全部楼层
thanks a lot
发表于 2010-2-18 07:50:11 | 显示全部楼层
thanks a lot
GMT+8, 2025-9-15 02:15 , Processed in 0.021878 second(s), 7 queries , Gzip On, Redis On.
