查看: 3724|回复: 8
[原创] DSP设计范例:FIR程序设计(VHDL)
发表于 2006-1-25 05:19:26 | 显示全部楼层 |阅读模式
-- FIR Digital Filter Design (DSP example)
-- VHDL Data-Flow modeling
-- KEYWORD:
-- generate, array, range, constant and subtype
library IEEE;-- declare the library
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
entity FIR_filter is
port(rst:instd_logic;
clk:instd_logic;
coef_ld:instd_logic;
start:instd_logic;
o_enable:instd_logic;
bypass:instd_logic;
Xn_in:in std_logic_vector(3 downto 0);
Yn_in:instd_logic_vector(15 downto 0);
Xn_oututstd_logic_vector(3 downto 0);
Yn_oututstd_logic_vector(15 downto 0)
end FIR_filter;
architecture BEH of FIR_filter is
    constant K:integer := 4;-- circuit has four stages
    -- use type and subtype to define the complex signals
    subtype bit4 isstd_logic_vector(3 downto 0);
    subtype bit8 isstd_logic_vector(7 downto 0);
    subtype bit16 isstd_logic_vector(15 downto 0);
    type klx4isarray (K downto 0) of bit4;
    type kx8isarray (K-1 downto 0) of bit8;
    type klx8is      array (K downto 0) of bit8;
    type kx16isarray (K-1 downto 0) of bit16;
    type klx16isarray (K downto 0) of bit16;
    -- define signal in type of arrays
    signalREG1, REG2, COEF: klx4;
    signalMULT8: kx8;
    signalMULT16: kx16;
    signalSUM: klx16;
    signalXn_tmp: bit4;
    signalYn_tmp: bit16;
begin
    -- initialize the first stage
of FIR circuit
    REG2(K)<= Xn_in when (start='1')
else (REG2(K)'range => '0');
    REG1(K) <= (REG1(K)'range => '0');
    SUM(K)  <= Yn_in;
    COEF(K) <= Xn_in;
    -- start the computation, use generate to obtain the
    -- multiple stages
    gen8:for j in K-1 downto 0 generate
        stages:process (rst, clk)
        begin
            if (rst='0') then
        REG1(j) <= (REG1(j)'range => '0');
        REG2(j) <= (REG2(j)'range => '0');
        COEF(j) <= (COEF(j)'range => '0');
        MULT16(j) <= (MULT16(j)'range => '0');
        SUM(j) <= (SUM(j)'range => '0');
    elsif (clk'event and clk ='1') then
        REG1(j) <= REG2(j+1);
        REG2(j) <= REG1(j);
        if (coef_ld = '1') then
            COEF(j) <= COEF(j+1);
          end if;
                MULT8(j) <= signed(REG1(j))*signed(COEF(j));
        MULT16(j)(7 downto 0) <= MULT8(j);
        if (MULT8(j)(7)='0') then
            MULT16(j)(15 downto 8) <= "00000000";
        else
            MULT16(j)(15 downto 8)  <=  "11111111";
        end if;
        SUM(j) <= signed(MULT16(j))+signed(SUM(j+1));
    end if;
        end process;
    end generate;
    -- control the outputs by concurrent statements
    Xn_tmp <= Xn_inwhen bypass = '1' else
REG2(0) when coef_ld = '0' else
COEF(0);
    Yn_tmp <= Yn_inwhen bypass = '1' else
SUM(0);
    Xn_out <= Xn_tmpwhen o_enable = '0' else
(Xn_out'range => 'Z');
    Yn_out <= Yn_tmpwhen o_enable = '0' else
(Yn_out'range => 'Z');
end BEH;
发表于 2006-11-1 19:13:30 | 显示全部楼层
顶一下!!
发表于 2006-11-15 16:27:11 | 显示全部楼层
顶一下。。
发表于 2006-11-16 14:27:33 | 显示全部楼层
路过...
发表于 2007-7-7 20:32:52 | 显示全部楼层
特意路过
发表于 2009-2-22 10:48:05 | 显示全部楼层
eetop
发表于 2009-2-22 10:49:32 | 显示全部楼层
eetop
发表于 2009-9-4 22:15:13 | 显示全部楼层
顶一下,赞!
发表于 2009-9-4 22:16:33 | 显示全部楼层
有没有VERILOG的啊?
GMT+8, 2025-12-14 11:53 , Processed in 0.024539 second(s), 9 queries , Gzip On, Redis On.
