楼主 |
发表于 2009-2-7 15:17:18
显示全部楼层
原帖由 suiwinder 于 2009-2-7 13:38 发表
能不能搞一个比较详细的说明啊。
1) Generate license using this .src with EFA Licgen 0.4b
  using Custom hostid with your [lmhostid]
2) Determine "secret value" of generated license with sssverify
  from SSS Keygen
3) Generate SSS feature with SSS Keygen using "secret value" and hostid
4) Change SSS feature in generated license at step 1 to new SSS feature,
  generated at step 3 (file license.dat)
6) Test license with original sssverify from SCL.
5) DO NOT INSERT "SERVER", "DAEMON", "USE_SERVER" into license!
  DO NOT USE SCL!
  DO NOT USE lmgrd!
6) Put path to generated license file into LM_LICENSE_FILE env. var.
7) Enjoy! |
