查看: 3130|回复: 1
[原创] 求助: 帮我改一下这个vc33代码 急啊!
发表于 2005-6-7 10:51:03 | 显示全部楼层 |阅读模式
frank98470868@sina.com
以下是实现 基于vc33的fir滤波器:
;Serial Port 0 registers
                        .global        BEGIN
sport                .set    808040h                ; Serial Port 0 global control register
xpctrl      .set    808042h             ; FSX/DX/CLKX port control
rpctrl      .set    808043h             ; FSR/DR/CLKR port control
rxtctrl     .set    808044h             ; r/x timer control register
rxtcnt      .set    808045h             ; r/x timer counter register
rxtprd      .set    808046h             ; r/x period register
xdata       .set    808048h             ; Data transmit register
rdata       .set    80804Ch            ; Data receive register
t0_GO       .set    001cfh              ; Timer configuration to GO
giebit            .set        2000h                ; GIE bit in ST register
eint3_cpu   .set    08h                 ; Enable bit for INT3 in IE register
int3_cpu_if .set    08h                 ; INT3 bit in IF register
                        .data
s0_rxcntr   .int    00000000h        ; Serial Clock will be configured
s0_rxprd    .int    00020002h        ; to run at 3.125 MHz
sp0_cfg           .word   0c140044h        ; SP0 GCR configuration word
adc_init    .word   0000a000h        ; ADC initialization word
adc_cfg     .word   0000a022h        ; repeat mode configuration word
adc_sel_0   .word   00000000h           ; to read input channel 0
adc_sel_1   .word   00001000h           ; to read input channel 1
fifo_read        .word        0000e000h        ; FIFO read command
DP_reg          .word        00800000h         ; DP pointer
startData        .word        00809c10h        ; start of data in RAM
endData                .word        00809d0fh        ; end of data in RAM
outnew_addr .word   00800d10h           ;
stack_addr  .word   00800e0fh           ;
xn_addr                 .word        xn
hn_addr                 .word        hn
xnnew_addr  .word   00809c14h           ;
hn                .int         1,2
xn                .int    3, 1
N                .word        6
*        Main Program
                        .text
begin        ldp           DP_reg                        ; Load Data Page pointer
                ldi                @stack_addr,sp
                ldi                @N,bk
                ldi            4,rc
                ldp                hn_addr
                ldi                @hn_addr,ar0
                ldi                @xn_addr,ar1
                ldi                @xnnew_addr,ar2
                ldi                @outnew_addr,ar3
loop        ldf                *ar2,r6
                stf                r6,*ar1++(1)%
                call        fir
                stf                r0,*AR3
            br                loop
*      FIR
fir                mpyf3        *ar0++(1),*ar1++(1)%,r0      ; 初始化R0?h(N-1)*x(n-(N-1))=R0
                ldf                0.0,r2                       ; 初始化R2
                rpts    rc                           ; 设置重复次数
        mpyf3        *ar0++(1),*ar1++(1)%,r0      ; h(N-1-i)*x(n-(N-1-i))=R0
            ||addf3        r0,r2,r2                     ; 乘累加
                addf3        r0,r2,r0                     ; 加上最后一个乘积
                rets                                 ; 返回
.end
* Place assembly initialization routine and interrupt vectors here
                .sect "vectors"
               b            int_isr
                      .end                        ; end of repeat_mode
发表于 2007-6-3 21:49:09 | 显示全部楼层
hao hao !
GMT+8, 2025-12-16 03:42 , Processed in 0.020147 second(s), 7 queries , Gzip On, Redis On.
