查看: 2790|回复: 5
Determining Clock Accuracy Requirements for UART Communications
发表于 2008-12-30 17:37:31 | 显示全部楼层 |阅读模式
Determining Clock Accuracy Requirements for UART Communications.pdf
169.93 KB, 下载次数: 11 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-12-30 17:38:13 | 显示全部楼层
This application note discusses the timing requirements for the commonly used serial asynchronous
communications protocol implemented in UARTs, and shows how to determine the tolerance for the UART clock
source at both ends of an asynchronous link.
 楼主| 发表于 2008-12-30 17:38:49 | 显示全部楼层
Background
The RS-232 specification dates back to 1962, when it was first released by the EIA (Electronic Industries
Association). The specification has changed over time, incorporating higher data rates and closing the
compatibility gaps between TIA (Telecommunication Industry Association) and international (ITU, ISO)
standards. The current version of the RS-232 specification is EIA/TIA-232-F, dated October 1997.
The protocol benefited from the availability of MSI ICs from the late 1970s which had the complexity to handle
the standard at reasonable cost. These ICs are generically called UARTs (Universal Asynchronous Receive
Transmit). Many LSI ICs (including microcontrollers) now include the functionality.
As is often the case, the availability of UARTs drove the industry to use the RS-232 serial protocol in non-RS-232
ways. Common examples are RS-485 transmissions, opto-isolated transmissions, and transmissions using a
single-ended physical layer (i.e. 0 - 3.3V instead of ±5V or ±10V). This note covers the general timing aspects
of the serial interface, not application nuances of handshaking or the physical layer, and so is applicable to all
generalized UART applications.
 楼主| 发表于 2008-12-30 18:46:28 | 显示全部楼层
maxim
发表于 2009-8-19 01:13:30 | 显示全部楼层
Thanks a lot~~ 感謝分享~
发表于 2013-11-6 17:06:04 | 显示全部楼层
Thanks a lot
GMT+8, 2025-12-19 06:46 , Processed in 0.019163 second(s), 5 queries , Gzip On, Redis On.
