查看: 9027|回复: 6
导入ncsu-cdk-1.5.1后,无法打开里面的电路和版图等
发表于 2008-12-28 17:01:49 | 显示全部楼层 |阅读模式
我按照网上的的方法导入ncsu-cdk-1.5.1后
library manger 里面显示正常,但是schematic 或layout都打不开
以下warning:
*WARNING* ddMapGetFileViewType: You are trying to run an OA executable on a CDB library file 'layout.cdb'. The file is in library 'MOSIS_Layout_Test' in cell 'M1_BASE' in view 'symbolic'. Use cdb2oa to convert your data from CDB to OA and then try again.
*WARNING* ddsServOpen: Unable to find view type for MOSIS_Layout_Test/M1_BASE/symbolic/layout.cdb
*WARNING* ddMapGetFileViewType: You are trying to run an OA executable on a CDB library file 'sch.cdb'. The file is in library 'NCSU_Analog_Parts' in cell '00_Complete_Index_00' in view 'schematic'. Use cdb2oa to convert your data from CDB to OA and then try again.
发表于 2010-2-13 22:10:05 | 显示全部楼层
你不看人家说明的,人家都说了只支持5141,你非要用在610上面,不行了吧,人家又说了,告诉你,用cdb2oa转换一下,你没看见呀,丢
发表于 2010-3-15 22:16:08 | 显示全部楼层
加油哦
发表于 2010-6-19 12:23:34 | 显示全部楼层
2# yejingang 本人菜鸟~ 请问下cdb2oa转换怎么弄阿?  谢谢!
发表于 2010-6-19 12:25:00 | 显示全部楼层
1# jianxuesheng 楼主~ 问题解决了吗? 在下也遇到了相同的问题~ 请教下楼主是怎么解决的~
发表于 2014-6-12 17:01:48 | 显示全部楼层
1024   a
发表于 2020-11-19 16:20:39 | 显示全部楼层
YOUQINGKEYUAN
GMT+8, 2025-12-12 04:56 , Processed in 0.023905 second(s), 7 queries , Gzip On, Redis On.
