查看: 39595|回复: 141
发一本论坛中尚未有的 Amazom四星半书 High Speed Signal Propagation
发表于 2008-12-12 00:25:08 | 显示全部楼层 |阅读模式
High Speed Signal Propagation: Advanced Black Magic (Prentice Hall Modern Semiconductor Design Series' Sub Series: PH Signal Integrity Library) (Hardcover)by Howard Johnson (Author)
4 Reviews
5 star:
(2)
4 star:
(2)
3 star: (0)
2 star: (0)
1 star: (0)
See all 4 customer reviews...
(4 customer reviews)
List Price:$115.00
Price:$103.23 & this item ships for FREE with Super Saver Shipping. Details
You Save:$11.77 (10%)
In Stock.
Ships from and sold by Amazon.com. Gift-wrap available.
Only 4 left in stock--order soon (more on the way).
Want it delivered Friday, December 12?  Order it in the next 6 hours and 41 minutes, and choose One-Day Shipping at checkout.
See details
Ordering for Christmas? To ensure delivery by December 24, choose FREE Super Saver Shipping at checkout. Read more about holiday shipping.
Prentice.High-Speed.Signal.Propagation.Advanced.Black.Magic.e.part1.rar
4.77 MB, 下载次数: 937 , 下载积分: 资产 -3 信元, 下载支出 3 信元
Prentice.High-Speed.Signal.Propagation.Advanced.Black.Magic.e.part2.rar
1.02 MB, 下载次数: 852 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-12-12 00:28:12 | 显示全部楼层
大家如有需要其他SI书籍,可以留言,我会继续发!!!
发到你不想要,嘿嘿....
发表于 2008-12-12 01:43:09 | 显示全部楼层
谢谢好书。
我知道不少好书。如果你能发的话我就不停的要,要到你发不出:)
先要这本:
Parallel Computing Using the Prefix Problem
http://www.amazon.com/Parallel-Computing-Using-Prefix-Problem/dp/0195088492
发表于 2008-12-12 08:38:02 | 显示全部楼层
好东西
谢谢,楼主
 楼主| 发表于 2008-12-12 10:45:20 | 显示全部楼层
注意啊,我说得是SI的,不是所有的书啊,哈哈
所以对于3楼的要求,我很难满足啊,哈哈哈
发表于 2008-12-13 11:24:45 | 显示全部楼层
good, 3x
发表于 2008-12-13 18:15:24 | 显示全部楼层
Good! THanks!
发表于 2008-12-13 21:31:59 | 显示全部楼层
楼主,我给你来点有挑战性的,不要光吹牛,我想要下面这本书,你             有吗?
Advanced Signal Integrity for High-Speed Digital Designs
Preface.
Acknowledgments.
Chapter 1: Introduction: The importance of signal integrity.
1.1 Computing Power: Past and Future.
1.2 The problem.
1.3 The Basics.
1.4 A new realm of bus design.
1.5 Scope.
1.6 Summary.
1.7 References.
Chapter 2: Electromagnetic Fundamentals for Signal Integrity.
2.1 Introduction.
2.2 Maxwell’s Equations.
2.3 Common Vector Operators.
2.4 Wave Propagation.
2.5 Electrostatics.
2.6 Magnetostatics.
2.7 Power Flow and the Poynting Vector.
2.8 Reflections of Electromagnetic Waves.
2.9 References.
2.10 Problems.
Chapter 3: Ideal Transmission Line Fundamentals.
3.1 Transmission Line Structures.
3.2 Wave propagation on loss free transmission lines.
3.3 Transmission line properties.
3.4 Transmission line parameters for the loss free case.
3.5 Transmission line reflections.
3.6 Time domain Reflectometry.
3.7 References.
3.8 Problems.
Chapter 4: Crosstalk.
4.1 Mutual Inductance and Capacitance.
4.2 Coupled Wave Equations.
4.3 Coupled Line Analysis.
4.4 Modal Analysis.
4.5 Crosstalk Minimization.
4.6 Summary.
4.7 References.
4.8 Problems.
Chapter 5: Non-ideal conductor models for transmission lines.
5.1 Signals propagating in an unbounded conductive media.
5.2 Classic conductor model for transmission lines.
5.3 Surface Roughness.
5.4 Transmission line parameters with a non-ideal conductor.
5.5 Problems.
Chapter 6: Electrical properties of dielectrics.
6.1 Polarization of dielectrics.
6.2 Classification of dielectric materials.
6.3 Frequency dependent dielectric behavior.
6.4 Properties of a physical dielectric model.
6.5 The fiber-weave effect.
6.6 Environmental variation in dielectric behavior.
6.7 Transmission line parameters for lossy dielectrics and realistic conductors.
6.8 References.
6.9 Problems.
Chapter 7: Differential signaling.
7.1 Removal of common mode noise.
7.2 Differential Crosstalk.
7.3 Virtual reference plane.
7.4 Propagation of Modal Voltages.
7.5 Common terminology.
7.6 Drawbacks of differential signaling.
7.7 References.
7.8 Problems.
Chapter 8: Mathematical Requirements of Physical Channels.
8.1 Frequency domain effects in time domain simulations.
8.2 Requirements for a physical Channel.
8.3 References.
8.4 Problems.
Chapter 9: Network Analysis for Digital Engineers.
9.1 High frequency voltage and current waves.
9.2 Network Theory.
9.3 Properties of Physical S-parameters.
9.4 References.
9.5 Problems.
Chapter 10: Topics in High-Speed Channel Modeling.
10.1 Creating a physical transmission line mode.
10.2 Non-Ideal Return Paths.
10.3 Vias.
10.4 References.
10.5 Problems.
Chapter 11: I/O Circuits and Models.
11.1 Introduction.
11.2 Push-Pull Transmitters.
11.3 CMOS Receivers.
11.4 ESD Protection Circuits.
11.5 On-Chip Termination.
11.6 Bergeron Diagrams.
11.7 Open Drain Transmitters.
11.8 Differential Current Mode Transmitters.
11.9 Low Swing/Differential Receivers.
11.10 IBIS Models.
11.11 Summary.
11.12 References.
11.13 Problems.
Chapter 12: Equalization.
12.1 Introduction.
12.2 Continuous Time Linear Equalizers.
12.3 Discrete Linear Equalizers.
12.4 Decision Feedback Equalization.
12.5 Summary.
12.6 References.
12.7 Problems.
Chapter 13: Modeling and Budgeting of Timing Jitter and Noise.
13.1 The Eye Diagram.
13.2 Bit Error Rate.
13.3 Jitter Sources and Budgets.
13.4 Noise Sources and Budgets.
13.5 Peak Distortion Analysis Methods.
13.6 Summary.
13.7 References.
13.8 Problems.
Chapter 14: System Analysis Using Response Surface Modeling.
14.1 Introduction.
14.2 Case Study: 10 Gb/s differential PCB interface.
14.3 RSM Construction by Least Squares Fitting.
14.4 Measures of Fit.
14.5 Significance Testing.
14.6 Confidence Intervals.
14.7 Sensitivity Analysis and Design Optimization.
14.8 Defect Rate Prediction Using Monte Carlo Simulation.
14.9 Additional RSM Considerations.
14.10 Summary.
14.11 References.
14.12 Problems.
Appendix A: Useful formulae, identities, units and constants.
Appendix B: 4-port Conversions between T and S-parameters.
Appendix C: Critical values of the F-statistic.
Appendix D: Critical values of the t-statistic..
Appendix E: Derivation of the internal inductance using the Hilbert Transform.
发表于 2008-12-14 15:44:45 | 显示全部楼层
还是谢谢
发表于 2008-12-14 15:46:46 | 显示全部楼层
再次感谢了
GMT+8, 2025-10-29 17:14 , Processed in 0.040711 second(s), 9 queries , Gzip On, Redis On.
