查看: 9941|回复: 12
求安捷伦《Electronic Test Instruments : Analog and Digital Measurements》
发表于 2008-12-9 01:15:59 | 显示全部楼层 |阅读模式
Electronic Test Instruments : Analog and Digital Measurements, 2nd Ed.
Auteur(s) : WITTE Robert A.
Date de parution: 04-2002
Langue : ANGLAIS
Env. 372p. 18.5x24 Hardback
Etat : Épuisé
Résumé
For every electronics professional, Electronic Test Instruments: Analog and Digital Measurements offers a thorough survey of the field of electronics instrumentation: devices and techniques, digital and analog.KEY TOPICS:Witte introduces basic measurement theory, along with commonly used electronic test equipment -- including meters, signal sources, oscilloscopes, frequency counters, power supplies, spectrum analyzers, network analyzers and logic analyzers. He presents detailed examples of applying each type of equipment in real-world applications, emphasizing basic functionality and guidance on choosing the instrument most likely to obtain a valid measurement. He offers a unified treatment of both analog and digital devices, explaining their commonalities and differences, while presenting up-to-the-minute coverage of the measurement techniques required by todays advanced digital systems.MARKET:For all engineers, technicians, and students who understand basic electronics and want a deeper understanding of electronic measurements.
Sommaire
Preface.
Acknowledgments
1. Measurement Theory.
Electrical Quantities. Resistance. Polarity. Direct Current. Power. Alternating Current. RMS Value. Average Value. Crest Factor. Phase. AC Power. Nonsinusoidal Waveforms. Harmonics. Square Wave. Pulse Train. Combined DC and AC. Modulated Signals. Decibels. Absolute Decibel Values. Measurement Error. The Loading Effect. The Voltage Divider. Maximum Voltage Transfer. Maximum Power Transfer. Impedance. Instrument Inputs. Bandwidth. Rise Time. Bandwidth Limitation on Square Wave Digital Signals. Logic Families. References.
2. Voltmeters, Ammeters, and Ohmmeters Meters.
DC Voltmeters. AC Voltmeters. RF Probes. Ammeters. Ammeter Used as a Voltmeter. Voltmeter Used as an Ammeter. Current-Sense Resistor. AC Ammeter. Ohmmeters. Voltmeter-Ammeter Method. Series Ohmmeter. Current-Source Method. 4-Wire Ohms Measurements. Multimeters. Meter Range. Other Multimeter Functions. Specifications. References.
3. Signal Sources.
Circuit Model. Floating and Grounded Outputs. Sine Wave Sources. Imperfections in Sine Wave Sources. Function Generators. Pulse Generators. RF Signal Generators. Summary of Signal Sources. References.
4. The Oscilloscope Concept.
Analog Scope Block Diagram. Digital Scope Block Diagram. Sample Rate. Real-Time Sampling. Repetitive Sampling. Triggering. Acquisition/Sweep Control. Vertical Amplifier. Vertical Resolution. AC and DC Coupling. Bandwidth Limit. X-Y Display Mode. High Impedance Inputs. 50-W Inputs. Digital Acquisition and Display Techniques. Oscilloscope Specifications. Scopesmanship. Mixed Signal Oscilloscope. Oscilloscope Probes. Probe Compensation. Active Probes. Differential Measurements. High-Voltage Probe. Current Probes. References.
5. Basic Waveform Measurements.
Voltage Gain Measurement. Phase Measurement. Frequency Measurement (Lissajous Method). Digital Signal Measurement. Frequency Response Measurement. Square Wave Test. Linearity Measurement. Curve Tracer Measurement Technique. Diode I-V Characteristic. Resistor I-V Characteristic. Amplitude Modulation Measurement. Power Measurement. FFT Measurements. Basic Time Domain Reflectometry. References.
6. Electronic Counters.
Basic Frequency Counter. Frequency Dividers. Period Measurement. Reciprocal Counter. Universal Counter. Gated Counter Measurements. Timebase Accuracy. Input Impedance. Frequency Counter Specifications. Time Interval Analyzer. References.
7. Power Supplies.
Power Supplies. Circuit Model. Constant-Voltage Operation. Constant-Current Operation. CV-CC Operation. Overvoltage/Overcurrent Protection. Remote Sensing. Measurement Capability. Power Supply Specifications. References.
8. Spectrum and Network Analyzers.
Spectrum Analyzers. Bank-of-Filters Spectrum Analyzer. FFT Spectrum Analyzers. Wavemeters. Resolution Bandwidth. Narrowband and Broadband Measurements. Swept Spectrum Analyzers. Spectrum Analyzer Measurements. Network Analyzers. Distortion Analyzers. RF Power Measurements. RF Power Meter. References.
9. Logic Analyzers.
Logic Probes. Oscilloscope Logic Measurements. Logic Analyzers. Timing Analyzer. Glitch Detect. Digital Logic Test Example. State Analyzer. Data Formats. State Display. Timing Display. Microprocessor Measurement. Storage Qualification. Trigger Events and Sequencing. Microprocessor Program Flow. Logic Analyzer Probing. Combined Scope and Logic Analyzer. PC-Hosted Logic Analyzer. References.
10. Circuits for Electronic Measurements.
Resistance Measurement-Indirect Method. Output Resistance. Input Resistance. Bridge Measurements. RL and RC Circuits. Resonant Circuits. Diode Measurement Circuit. Instrument Connections. Attenuators. Power Splitters and Combiners Measurement Filters. References.
Appendix A: Table o
安捷伦公司的技术人员编写的。非常好,不知哪位能上传一下。提前谢了
头像被屏蔽
发表于 2008-12-9 06:22:40 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-12-9 14:50:05 | 显示全部楼层
这个不好搞吧
 楼主| 发表于 2008-12-9 23:05:22 | 显示全部楼层
大家共同努力
原帖由 qwneo 于 2008-12-9 14:50 发表
这个不好搞吧
在学校的同学可以到学校图书馆的电子资源上面收缩一下。
替全国人名谢你们
头像被屏蔽
发表于 2008-12-10 03:53:06 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2009-4-13 17:23:54 | 显示全部楼层
可惜还没有下到啊
这期间到时看了一些其他类似的文献。看来得花血本来找这些东东了哟
发表于 2009-10-23 01:41:41 | 显示全部楼层
thank
发表于 2009-10-24 23:29:09 | 显示全部楼层
学校能下吗?
发表于 2009-11-1 09:14:54 | 显示全部楼层
学校也不一定有吧
发表于 2010-8-3 10:05:27 | 显示全部楼层
我也需要。。。
GMT+8, 2025-12-22 06:47 , Processed in 0.020948 second(s), 6 queries , Gzip On, Redis On.
