查看: 10333|回复: 33
ARM Architecture Reference Manual
发表于 2008-12-3 21:06:56 | 显示全部楼层 |阅读模式
About this manualThe purpose of this manual is to describe the ARM instruction set architecture, including its high codedensity Thumb® subset, and three of its standard coprocessor extensions:• The standard System Control coprocessor (coprocessor 15), which is used to control memory systemcomponents such as caches, write buffers, Memory Management Units, and Protection Units.• The Vector Floating-point (VFP) architecture, which uses coprocessors 10 and 11 to supply ahigh-performance floating-point instruction set.• The debug architecture interface (coprocessor 14), formally added to the architecture in ARM v6 toprovide software access to debug features in ARM cores, (for example, breakpoint and watchpointcontrol).The 32-bit ARM and 16-bit Thumb instruction sets are described separately in Part A. The precise effectsof each instruction are described, including any restrictions on its use. This information is of primaryimportance to authors of compilers, assemblers, and other programs that generate ARM machine code.Assembler syntax is given for most of the instructions described in this manual, allowing instructions to bespecified in textual form.However, this manual is not intended as tutorial material for ARM assembler language, nor does it describeARM assembler language at anything other than a very basic level. To make effective use of ARM assemblerlanguage, consult the documentation supplied with the assembler being used.The memory and system architecture definition is significantly improved in ARM architecture version 6 (thelatest version). Prior to this, it usually needs to be supplemented by detailed implementation-specificinformation from the technical reference manual of the device being used.
ARM Architecture Reference Manual.part1.rar
2.86 MB, 下载次数: 213 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-12-3 21:09:12 | 显示全部楼层
part2
ARM Architecture Reference Manual.part2.rar
2.61 MB, 下载次数: 222 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-12-4 15:30:27 | 显示全部楼层
最新的版本
Copyright © 1996-1998, 2000, 2004, 2005 ARM Limited. All rights reserved.
Release Information
Change History
Date Issue Change
February 1996 A First edition
July 1997 B Updated and index added
April 1998 C Updated
February 2000 D Updated for ARM architecture v5
June 2000 E Updated for ARM architecture v5TE and corrections to Part B
July 2004 F Updated for ARM architecture v6 (Confidential)
December 2004 G Updated to incorporate corrections to errata
March 2005 H Updated to incorporate corrections to errata
July 2005 I Updated to incorporate corrections to pseudocode and graphics
发表于 2008-12-4 17:09:16 | 显示全部楼层
不错啊,学习学习
发表于 2008-12-13 21:32:09 | 显示全部楼层
好东西,就是信元不够了,嘿嘿
发表于 2008-12-13 21:36:16 | 显示全部楼层
下了一个,再次感谢了
发表于 2009-1-1 20:51:19 | 显示全部楼层
many thanks
发表于 2009-4-14 10:04:27 | 显示全部楼层
下载bul
发表于 2009-4-20 11:23:52 | 显示全部楼层
VERY GOOD
发表于 2009-4-20 11:41:56 | 显示全部楼层
lz  怎么打不开
GMT+8, 2025-12-23 22:34 , Processed in 0.028280 second(s), 7 queries , Gzip On, Redis On.
