查看: 11267|回复: 46
[EBOOK]Wiley,CDMA: Access and Switching: For Terrestrial and Satellite Networks
发表于 2004-7-3 12:08:19 | 显示全部楼层 |阅读模式
by Diakoumis Gerakoulis, Evaggelos Geraniotis
CDMA: Access and Switching addresses two unique uses of CDMA. The first is its use as a generalized method for multiple access communications and the second is its use in switching applications. Hence, the concepts introduced will enable readers to understand that multi-user communications (whether access or switching) can be presented as generalized code division networks. Each new application presented is assessed and evaluated while each innovative design is followed by rigorous performed analysis.
*Introduces the concepts of generalized CDMA and code division switching and analyzes spreading sequences for orthogonal, quasi-orthogonal and pseudo-orthogonal access systems
*Presents the Satelite Switched CDMA (SS/CDMA) as a system application and evaluates its end-to-end BER performance and throughput
*Features methods and procedures for random access, synchronization and carrier demodulation in CDMA networks and examines the CDMA performance under non-linear amplification
*Discusses methods of adaptive power control and multi-user detection in asynchronous CDMA networks
Such a novel approach will be of great interest to researchers and will also benefit forward-looking system architects and designers. For graduate level students undergoing research work in terrestial wireless and satellite networks it will be a unique learning experience.
Table of Contents
The Generalized CDMA.
Spreading Sequences.
Switched CDMA Networks.
Code Division Switching.
The Satellite Switched CDMA Throughput.
The Spectrally Efficient CDMA Performance.
Network Access and Synchronization.
Carrier Recovery for 'Sub-Coherent' CDMA.
Nonlinear Amplification of Synchronous CDMA.
Optimization Techniques for 'Pseudo-Orthogonal' CDMA.
 楼主| 发表于 2004-7-3 12:09:15 | 显示全部楼层
LBHIDDEN[0]LBHIDDENCDMA: Access and Switching: For Terrestrial and Satellite Networks
发表于 2004-9-15 20:14:03 | 显示全部楼层
sgdhfnvb
发表于 2004-11-4 18:31:13 | 显示全部楼层
好好好!
发表于 2004-11-4 22:43:30 | 显示全部楼层
发表于 2005-2-14 06:06:55 | 显示全部楼层
good
发表于 2005-2-24 20:43:16 | 显示全部楼层
没了?
发表于 2005-2-27 22:44:48 | 显示全部楼层
看不到 ??
发表于 2005-3-31 10:41:54 | 显示全部楼层
没有了,怎么回事啊?哪位好心人再上传一次啊。
发表于 2005-4-10 02:26:08 | 显示全部楼层
既然要贡献,干吗还要加条件.
GMT+8, 2025-12-21 22:27 , Processed in 0.025574 second(s), 9 queries , Gzip On, Redis On.
