楼主: analoger
请教各位关于boost converter 系统稳定的问题
发表于 2009-6-15 22:41:25 | 显示全部楼层
有图吗?
发表于 2009-6-18 09:22:16 | 显示全部楼层
上面有人说了
你在低频处是负增益
应该加上误差放大器
使得变成正增益。
然后看0DB时的
相位裕量
发表于 2009-7-8 16:59:35 | 显示全部楼层
loop gain 该是正的才对,估计你建模有问题!
发表于 2009-7-13 00:43:06 | 显示全部楼层
要把放大器加上,增益都负了。
貌似在10E5频率上有双极点重合,要注意,可能会不稳定。
发表于 2009-8-27 17:43:16 | 显示全部楼层
估计是设置错误导致的,根本就没有Gain嘛!
[ 本帖最后由 love_ic 于 2009-8-27 17:45 编辑 ]
发表于 2009-9-22 08:40:55 | 显示全部楼层
这肯定是稳定的,dc gain都是-40db
发表于 2010-12-14 10:41:56 | 显示全部楼层
's just the bode plot of the plant stage, seeing from the negative gain of the low frequency. Actually, you need to add the control circuit which will give enough gain at low frequency (for example, 80db or greater) and model the pwm block ( if you use such method, that means you need to model the switch and diode). After including the control circuit, the whole loop gain will be changed into positive, and you can measure the loop stablity. For system design, you need to get the model of the control IC(normally, can model it as OTA, and adding the compensation component).
发表于 2011-2-12 19:15:09 | 显示全部楼层
大家帮忙分析.......
GMT+8, 2025-12-24 04:38 , Processed in 0.016412 second(s), 3 queries , Gzip On, Redis On.
