查看: 1796|回复: 3
基于DSP+FPGA+USB2.0开发板GPS卫星导航定位系统的开发
头像被屏蔽
发表于 2008-11-14 19:53:15 | 显示全部楼层 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-11-24 10:15:29 | 显示全部楼层
发表于 2009-2-20 21:35:58 | 显示全部楼层
骗人的??????
发表于 2009-3-29 20:25:51 | 显示全部楼层
Selected GPS Receiver Enhancements for Weak Signal Acquisition and Tracking
The sensitivity of a baseband signal processing unit, including both acquisition and
tracking, is critical for a GPS receiver to function in perturbed signal enviroments such as
indoors and under ionospheric scintillation.. To improve acquisition sensitivity, the dif-
ferential combining approach, which allows a 2.5 dB improvement in processing loss as
compared to noncoherent methods, is proposed herein. This results in a sensitivity im-
provement ranging from 1.2 dB to 1.6 dB for a given probability of false alarm and mi-
ssed detection.
Based on an analysis of the Costas-family PLLs, carrier tracking is enhanced by optimiz-
ing loop configurations. The decision-directed loop , exhibits a 2  -dB sensitivity im-
provement as compared to other types of PLLs. Bandwidth and root deviation caused by
bilinear or boxcar transforms are solved by implementing a root-controled method. Using
this design makes the bandwidth of the digital loop close to desired values, and thus im-
proves carrier tracking by another 1 to 2 dB. A Kalman Filter adopts a soft-mode to deal
with the bit sign uncertainty and adjusts the bandwidth to minimize the mean square car-
rier tracking error. This leads to a 4 dB and 7 dB sensitivity improvement during weak
and strong amplitude ionospheric scintillations, respectively.
GMT+8, 2025-12-27 09:34 , Processed in 0.020677 second(s), 6 queries , Gzip On, Redis On.
