查看: 26328|回复: 188
IEEE LNA全套论文,最新成果,设计要素,基础理论。26篇4个包,内容丰富又实惠!
发表于 2008-11-9 18:47:43 | 显示全部楼层 |阅读模式
IEEE上的LNA全套论文,有的展示最新的设计成果,也有详述设计要点的概括,还有论述基础的噪声理论,含金量如何大家自有评论。
共压成4个包,大附件上传,极其实惠,我会给出每个包中的论文题名。
Part1:
1 A 1.2-V Highly Linear Balanced Noise-Cancelling LNA in 0.13-μm CMOS
2 A 1.5-V, 1.5-GHz CMOS Low Noise Amplifier
3 A 1-V, 5.5-GHz, CMOS LNA With Multiple Magnetic Feedback
4 A 2.7-V 900-MHz CMOS LNA and mixer
5 A 2.17-dB NF 5-GHz-band monolithic CMOS LNA with 10-mW DC power consumption
6 A 2-dB noise figure 900-MHz differential CMOS LNA
7 A 64 GHz LNA With 15.5 dB Gain and 6.5 dB NF in 90 nm CMOS
LNA_1-7.rar (4.51 MB , 下载次数: 778 )
 楼主| 发表于 2008-11-9 18:55:07 | 显示全部楼层
Part2:
8 A fully integrated differential CMOS LNA for 3-5-GHz ultrawideband wireless receivers
9 A Highly Linear Broadband CMOS LNA Employing Noise and Distortion Cancellation
10 A Low-Power Wideband CMOS LNA for WiMAX
11 A Magnetic Feedback Method for Low-Voltage CMOS LNA Reverse-Isolation Enhancement
12 A Noise Reduction and Linearity Improvement Technique for a Differential Cascode LNA
13 A Packaged and ESD-Protected Inductorless 0.1–8 GHz Wideband CMOS LNA
14 A Sub-2 dB NF Dual-Band CMOS LNA for CDMA or WCDMA Applications
15 An Ultra-Wide-Band 0.4–10-GHz LNA in 0.18-μm CMOS
16 Design of a 0.9 V 2.45 GHz Self-Testable and Reliability-Enhanced CMOS LNA.
LNA_8-16.rar (4.37 MB , 下载次数: 830 )
 楼主| 发表于 2008-11-9 19:10:01 | 显示全部楼层
Part3:
17 High-performance in W-band monolithic pseudomorphic InGaAs HEMT LNA's and design and analysis methodology
18 High-Q Above-IC Inductors Using Thin-Film Wafer-Level Packaging Technology Demonstrated on 90-nm RF-CMOS 5-GHz VCO and 24-GHz LNA.
19 High-Voltage-Gain CMOS LNA For 6–8.5-GHz UWB Receivers
20 Ka-Band SiGe HBT Low Phase Imbalance Differential 3-Bit Variable Gain LNA
21 Low-power programmable gain CMOS distributed LNA
22 Low-Power Short-Range Radio CMOS Subharmonic RF Front-End Using CG-CS LNA
23 MOSFET thermal noise modeling for analog integrated circuits
LNA_17-23.rar (4.84 MB , 下载次数: 656 )
 楼主| 发表于 2008-11-9 19:11:59 | 显示全部楼层
Part4:
24 RF noise characterization of MOS devices for LNA design using a physical-based quasi-3-D approach
25 SPICE simulation and tradeoffs of CMOS LNA performance with source-degeneration inductor
26 Sub-0.2 dB Noise Figure Wideband Room-Temperature CMOS LNA With Non-50 Ohm Signal-Source Impedance
LNA_24-26.rar (3.8 MB , 下载次数: 613 )
 楼主| 发表于 2008-11-9 19:24:12 | 显示全部楼层
不会吧,没人顶?自己顶一下,好歹也收集了,还充分考虑了穷人们,尽量把它们压成大附件分享出来。没人肯定一下吗?
 楼主| 发表于 2008-11-9 19:35:06 | 显示全部楼层
自己顶,直到有人下为止。
发表于 2008-11-9 19:56:32 | 显示全部楼层
我来下。。尊重兄弟劳动成果~顶
 楼主| 发表于 2008-11-9 20:34:12 | 显示全部楼层
再次顶起!
发表于 2008-11-9 21:13:55 | 显示全部楼层
可惜不做射频了
 楼主| 发表于 2008-11-9 23:37:34 | 显示全部楼层
再来一次.
GMT+8, 2025-12-25 18:41 , Processed in 0.023234 second(s), 6 queries , Gzip On, Redis On.
