查看: 7674|回复: 36
[原创] 【新】ADAPTIVE FILTER ARCHITECTURES FOR FPGA IMPLEMENTATION
发表于 2008-11-6 15:20:20 | 显示全部楼层 |阅读模式
1 Introduction
1.1 Purpose.................................................................................................................. 1
1.2 Overview............................................................................................................... 1
1.2.1 Advantages of DSP..................................................................................... 2
1.2.2 Reconfigurable Hardware Advantages ................................................... 2
1.3 Organization of Thesis ........................................................................................ 3
2 Programmable Logic Devices
2.1 History of Programmable Logic ......................................................................... 4
2.2 FPGA Architecture................................................................................................ 6
2.3 Device Configuration ........................................................................................... 9
2.3.1 Schematic Design Entry .............................................................................. 9
2.3.2 Hardware Description Languages ............................................................11
2.3.3 High‐Level Languages ................................................................................11
2.4 Current Trends ......................................................................................................12
3 Adaptive Filter Overview
3.1 Introduction .......................................................................................................... 13
3.2 Adaptive Filtering Problem................................................................................ 14
3.3 Applications.......................................................................................................... 15
3.4 Adaptive Algorithms........................................................................................... 16
3.4.1 Wiener Filters............................................................................................... 17
3.4.2 Method of Steepest Descent ...................................................................... 19
3.4.3 Least Mean Square Algorithm .................................................................. 20
3.4.4 Recursive Least Squares Algorithm ......................................................... 21
4 FPGA Implementation
4.1 FPGA Realization Issues ..................................................................................... 23
4.2 Finite Precision Effects ........................................................................................ 24
v
4.2.1 Scale Factor Adjustment............................................................................. 24
4.2.2 Training Algorithm Modification............................................................. 27
4.3 Loadable Coefficient Filter Taps........................................................................ 31
4.3.1 Computed Partial Products Multiplication............................................. 31
4.3.2 Embedded Multipliers ............................................................................... 34
4.3.3 Tap Implementation Results ..................................................................... 34
4.4 Embedded Microprocessor Utilization............................................................. 37
4.4.1 IBM PowerPC 405 ....................................................................................... 37
4.4.2 Embedded Development Kit..................................................................... 38
4.4.3 Xilinx Processor Soft IP .............................................................................. 38
4.4.3.1 User IP Cores ................................................................................... 39
4.4.4 Adaptive Filter IP Core .............................................................................. 41
5 Results
5.1 Methods Used....................................................................................................... 42
5.2 Algorithm Analyses............................................................................................. 44
5.2.1 Full Precision Analysis............................................................................... 44
5.2.2 Fixed‐Point Analysis................................................................................... 46
5.3 Hardware Verification......................................................................................... 48
5.4 Power Consumption............................................................................................ 49
5.5 Bandwidth Considerations................................................................................. 50
6 Conclusions
6.1 Conclusions........................................................................................................... 52
6.2 Future Work.......................................................................................................... 53
Appendix A Matlab Code........................................................................................... 55
Appendix B VHDL Code............................................................................................ 59
Appendix C C Code .................................................................................................... 75
Appendix D Device Synthesis Results ................................................................... 80
References ..................................................................................................................... 83
Biographical Sketch .................................................................................................... 86
ADAPTIVE FILTER ARCHITECTURES FOR FPGA IMPLEMENTATION.pdf
854.39 KB, 下载次数: 167 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-11-7 10:50:36 | 显示全部楼层
谢谢
楼主把封面贴出来啊
 楼主| 发表于 2008-11-7 12:34:08 | 显示全部楼层
其实是篇文章 不是书......
发表于 2008-11-11 15:45:38 | 显示全部楼层
xia look
发表于 2008-11-16 02:04:21 | 显示全部楼层
thanks a lot, I am looking for it
发表于 2008-11-26 12:37:45 | 显示全部楼层
没钱了 希望楼主理解 呵呵 谢谢
发表于 2008-12-2 16:25:17 | 显示全部楼层
thank you
发表于 2008-12-10 11:38:22 | 显示全部楼层
Good  !!!!
发表于 2008-12-25 14:01:36 | 显示全部楼层
谢谢楼主
发表于 2009-2-15 20:18:51 | 显示全部楼层
erghjkjh
GMT+8, 2025-12-25 03:27 , Processed in 0.025357 second(s), 6 queries , Gzip On, Redis On.
