楼主: mekenny
关于管子的叉指数m
发表于 2008-11-6 19:49:01 | 显示全部楼层
原帖由 belgium 于 2008-11-2 22:51 发表
it differs from layout type.
if you use figure, you mean to use source/drain sharing.
if you use multiple, it is not  to use sharing.
it is equal in low freauency design.
but if it is used in RF d ...
can u telll us, how to deal with this problem?
if the 'w' & 'l' is determined , how to make sure the 'figure'?
发表于 2008-11-10 13:35:12 | 显示全部楼层
当然不一样了,M=1和M=N的画法layout不一样,寄生效应就不一样,而且管子的VTH也不一样,对数字电路来说没有什么区别,对ANALOG来说区别大了。还有要分清楚M和F的区别。
GMT+8, 2025-9-16 19:52 , Processed in 0.629779 second(s), 3 queries , Gzip On, Redis On.
