查看: 8172|回复: 33
LDO with dynamic zero compensation
发表于 2008-10-30 23:09:08 | 显示全部楼层 |阅读模式
CMOS low dropout regulator with dynamic zero compensation
C.-L. Chen, W.-J. Huang and S.-I. Liu
The output capacitor and its equivalent series resistance (ESR) often
limit the stability of a conventional low dropout regulator (LDR). A
CMOS LDR with dynamic zero compensation is presented to tolerate
the wide range of the output capacitor and the ESR. The stability
constraints for the output capacitor with the ESR are derived. The
measured LDR is stable for the output capacitor 2nF–47uF with ESR
of 0.1–50 O. The maximum quiescent current of this LDR with a
bandgap reference is 43.2uA and its maximum output current is
150 mA for the output voltage of 1.8V.
EL_July_07.pdf
172.74 KB, 下载次数: 240 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-10-31 00:12:28 | 显示全部楼层
have a look
发表于 2008-11-9 19:52:46 | 显示全部楼层
1111111111111111111111
发表于 2008-11-9 19:54:04 | 显示全部楼层
3333333333333333333333333
发表于 2008-11-12 22:02:48 | 显示全部楼层
谢谢楼主了
发表于 2008-11-30 19:26:44 | 显示全部楼层
发表于 2009-3-27 16:15:18 | 显示全部楼层
采用负反馈得方法提高 PSRR
发表于 2009-12-7 19:40:23 | 显示全部楼层
下来看看哦
发表于 2009-12-7 21:22:24 | 显示全部楼层
ding,,
发表于 2009-12-7 21:31:32 | 显示全部楼层
good
good
goood
GMT+8, 2025-12-5 05:57 , Processed in 0.019363 second(s), 4 queries , Gzip On, Redis On.
