查看: 2269|回复: 1
Analog OPAMP assignment
发表于 2008-10-19 19:34:06 | 显示全部楼层 |阅读模式
Lecture 1 Introduction to Low-Power Design (powerpoint, 7 slides) 1/20/2006
Lecture 2 Physics of CMOS Power Dissipation (powerpoint, 46 slides) 1/20/2006
Lecture 3 Power Consumption and Limiting Factors (powerpoint, 26 slides) 1/20/2006
Lecture 4 Introduction to Power Estimation (powerpoint, 24 slides) 1/27/2006
Lecture 5 Statistical Power Estimation (powerpoint, 52 slides) 1/27/2006
Lecture 6 Circuit Level Power Estimation (powerpoint, 26 slides) 2/3/2006
Lecture 7 Behavioral Synthesis for Low-Power (powerpoint, 42 slides) 2/3/2006
Lecture 8 Logic/Circuit Synthesis for Low-Power (powerpoint, 37 slides) 2/10/2006
Lecture 9 Design & Leakages of Low-Voltage CMOS Devices (powerpoint, 48 slides) 2/10/2006
Lecture 10 Design & Test of Low-Voltage CMOS (powerpoint, 45 slides) 2/17/2006
Lecture 11 Low-Power Static RAM Architectures (powerpoint, 35 slides) 2/17/2006
Lecture 12 Low-Power Computing with Energy Recovery (powerpoint, 29 slides) 2/24/2006
Lecture 13 Partially reversible Logic and Quasi-Adiabatic Memories (powerpoint, 44 slides) 2/24/2006
Lecture 14 Software Design for Low Power (powerpoint, 33 slides) 3/3/2006
Lecture 15 Systemtic Low-Power Layout with Hazard Filtering and Balanced Delay (powerpoint, 1 slide) 3/3/2006
Lecture 16 Physical Design and Layout of Passive Analog Components (powerpoint, 45 slides) 3/10/2006
Lecture 17 Diode and Transistor Theory (powerpoint, 16 slides) 3/10/2006
Lecture 18 Physical Design and Layout of Diodes and Transistors (powerpoint, 50 slides) 3/10/2006
Lecture 19 MOS Amplifier Design (powerpoint, 82 slides) 3/24/2006
Lecture 20 Current Source Biasing and MOS Amplifier Design (powerpoint, 84 slides) 3/31/2006
Lecture 21 MOS Amplifier Compensation, Miller Effect (powerpoint, 156 slides) 4/7/2006
Lecture 22 Gilbert Cell Design (powerpoint, 5 slides) 4/14/2006
Lecture 23 Phase-Locked Loop and VCO Design (powerpoint, slides) 4/14/2006
Lecture 24 Sigma-Delta, A/D, and D/A Converter Design (powerpoint, slides) 4/14/2006
Lecture 25 Wireless Circuits (powerpoint, slides) 4/21/2006
Lecture 26 Filters (powerpoint, slides) 4/21/2006
Lecture 27 Integrated Radio Frequency (RF) CMOS Circuit Design (powerpoint, slides) 4/28/2006
发表于 2023-2-24 11:11:44 | 显示全部楼层
thanks
GMT+8, 2025-11-25 03:46 , Processed in 0.014781 second(s), 5 queries , Gzip On, Redis On.
