查看: 4335|回复: 4
wdm驱动程序如何能够访问pci设备的配置空间
发表于 2005-5-21 09:44:44 | 显示全部楼层 |阅读模式
wdm驱动程序发访问设备配置空间,请大家指教
发表于 2005-5-23 14:21:43 | 显示全部楼层
NTSTATUS PciConfigRegisterRead(PDEVICE_OBJECT fdo,ULONG *pReadValue,USHORT offset,UCHAR Length)
PIRP pIrp;
KEVENT event;
NTSTATUS status;
PIO_STACK_LOCATION stack;
UCHAR ReadLen;
pIrp = IoAllocateIrp(fdo->StackSize,FALSE
if (pIrp == NULL)
return STATUS_INSUFFICIENT_RESOURCES;
// Initialize kernel event
KeInitializeEvent(&event,NotificationEvent,FALSE);
stack =IoGetNextIrpStackLocation(pIrp);
switch ( Length )
case 1:ReadLen = sizeof(UCHAR);break;
case 2:ReadLen = sizeof(USHORT);break;
case 4:ReadLen = sizeof(ULONG);break;
default:ReadLen = sizeof(ULONG);break;
// Fill the IRP
pIrp->IoStatus.Status = STATUS_NOT_SUPPORTED;
stack->MajorFunction = IRP_MJ_PNP;
stack->MinorFunction = IRP_MN_READ_CONFIG;
stack->arameters.ReadWriteConfig.WhichSpace = 0;
stack->arameters.ReadWriteConfig.Buffer = pReadValue;
stack->arameters.ReadWriteConfig.Offset = offset;
stack->Parameters.ReadWriteConfig.Length = ReadLen;
IoSetCompletionRoutine(pIrp,(PIO_COMPLETION_ROUTINE)OnRequestComplete,(PVOID)&event,TRUE,TRUE,TRUE);
// Send the packet
status =IoCallDriver(fdo,pIrp);
if (status == STATUS_PENDING)
// Wait for completion
KeWaitForSingleObject(&event,Executive,KernelMode,FALSE,NULL);
status = pIrp->IoStatus.Status;
// Release the IRP
IoFreeIrp(pIrp);
return status;
NTSTATUS OnRequestComplete(PDEVICE_OBJECT fdo,PIRP pIrp,PKEVENT pKEvent)
KeSetEvent(pKEvent,0,FALSE);
return STATUS_MORE_PROCESSING_REQUIRED;
发表于 2009-1-19 01:34:36 | 显示全部楼层
不错的代码,谢谢
发表于 2009-11-20 15:15:33 | 显示全部楼层
不错!
发表于 2009-11-22 11:50:02 | 显示全部楼层
不错,谢谢分享
GMT+8, 2025-12-26 02:48 , Processed in 0.021022 second(s), 9 queries , Gzip On, Redis On.
