查看: 2171|回复: 3
高手帮我看看这段代码的意思
发表于 2008-10-10 20:03:33 | 显示全部楼层 |阅读模式
`include "timescale.v"
module eth_miim
  Clk,
  Reset,
  Divider,
  NoPre,
  CtrlData,
  Rgad,
  Fiad,
  WCtrlData,
  RStat,
  ScanStat,
  Mdi,
  Mdo,
  MdoEn,
  Mdc,
  Busy,
  Prsd,
  LinkFail,
  Nvalid,
  WCtrlDataStart,
  RStatStart,
  UpdateMIIRX_DATAReg
input         Clk;                // Host Clock
input         Reset;              // General Reset
input   [7:0] Divider;            // Divider for the host clock
input  [15:0] CtrlData;           // Control Data (to be written to the PHY reg.)
input   [4:0] Rgad;               // Register Address (within the PHY)
input   [4:0] Fiad;               // PHY Address
input         NoPre;              // No Preamble (no 32-bit preamble)
input         WCtrlData;          // Write Control Data operation
input         RStat;              // Read Status operation
input         ScanStat;           // Scan Status operation
input         Mdi;                // MII Management Data In
output        Mdc;                // MII Management Data Clock
output        Mdo;                // MII Management Data Output
output        MdoEn;              // MII Management Data Output Enable
output        Busy;               // Busy Signal
output        LinkFail;           // Link Integrity Signal
output        Nvalid;             // Invalid Status (qualifier for the valid scan result)
output [15:0] Prsd;               // Read Status Data (data read from the PHY)
output        WCtrlDataStart;     // This signals resets the WCTRLDATA bit in the MIIM Command register
output        RStatStart;         // This signal resets the RSTAT BIT in the MIIM Command register
output        UpdateMIIRX_DATAReg;// Updates MII RX_DATA register with read data
parameter Tp = 1;
reg           Nvalid;
reg           EndBusy_d;          // Pre-end Busy signal
reg           EndBusy;            // End Busy signal (stops the operation in progress)
reg           WCtrlData_q1;       // Write Control Data operation delayed 1 Clk cycle
reg           WCtrlData_q2;       // Write Control Data operation delayed 2 Clk cycles
reg           WCtrlData_q3;       // Write Control Data operation delayed 3 Clk cycles
reg           WCtrlDataStart;     // Start Write Control Data Command (positive edge detected)
reg           WCtrlDataStart_q;
reg           WCtrlDataStart_q1;  // Start Write Control Data Command delayed 1 Mdc cycle
reg           WCtrlDataStart_q2;  // Start Write Control Data Command delayed 2 Mdc cycles
reg           RStat_q1;           // Read Status operation delayed 1 Clk cycle
reg           RStat_q2;           // Read Status operation delayed 2 Clk cycles
reg           RStat_q3;           // Read Status operation delayed 3 Clk cycles
reg           RStatStart;         // Start Read Status Command (positive edge detected)
reg           RStatStart_q1;      // Start Read Status Command delayed 1 Mdc cycle
reg           RStatStart_q2;      // Start Read Status Command delayed 2 Mdc cycles
reg           ScanStat_q1;        // Scan Status operation delayed 1 cycle
reg           ScanStat_q2;        // Scan Status operation delayed 2 cycles
reg           SyncStatMdcEn;      // Scan Status operation delayed at least cycles and synchronized to MdcEn
wire          WriteDataOp;        // Write Data Operation (positive edge detected)
wire          ReadStatusOp;       // Read Status Operation (positive edge detected)
wire          ScanStatusOp;       // Scan Status Operation (positive edge detected)
wire          StartOp;            // Start Operation (start of any of the preceding operations)
wire          EndOp;              // End of Operation
reg           InProgress;         // Operation in progress
reg           InProgress_q1;      // Operation in progress delayed 1 Mdc cycle
reg           InProgress_q2;      // Operation in progress delayed 2 Mdc cycles
reg           InProgress_q3;      // Operation in progress delayed 3 Mdc cycles
reg           WriteOp;            // Write Operation Latch (When asserted, write operation is in progress)
reg     [6:0] BitCounter;         // Bit Counter
wire          MdcFrame;           // Frame window for limiting the Mdc
wire    [3:0] ByteSelect;         // Byte Select defines which byte (preamble, data, operation, etc.) is loaded and shifted through the shift register.
wire          MdcEn;              // MII Management Data Clock Enable signal is asserted for one Clk period before Mdc rises.
wire          ShiftedBit;         // This bit is output of the shift register and is connected to the Mdo signal
wire          LatchByte1_d2;
wire          LatchByte0_d2;
reg           LatchByte1_d;
reg           LatchByte0_d;
reg     [1:0] LatchByte;          // Latch Byte selects which part of Read Status Data is updated from the shift register
reg           UpdateMIIRX_DATAReg;// Updates MII RX_DATA register with read data
// Generation of the EndBusy signal. It is used for ending the MII Management operation.
always @ (posedge Clk or posedge Reset)
begin
  if(Reset)
    begin
      EndBusy_d <= #Tp 1'b0;
      EndBusy <= #Tp 1'b0;
    end
  else
    begin
      EndBusy_d <= #Tp ~InProgress_q2 & InProgress_q3;
      EndBusy   <= #Tp EndBusy_d;
    end
end
// Update MII RX_DATA register
begin
  if(Reset)
    UpdateMIIRX_DATAReg <= #Tp 0;
  else
  if(EndBusy & ~WCtrlDataStart_q)
    UpdateMIIRX_DATAReg <= #Tp 1;
  else
end
// Generation of the delayed signals used for positive edge triggering.
begin
  if(Reset)
    begin
      WCtrlData_q1 <= #Tp 1'b0;
      WCtrlData_q2 <= #Tp 1'b0;
      WCtrlData_q3 <= #Tp 1'b0;
      RStat_q1 <= #Tp 1'b0;
      RStat_q2 <= #Tp 1'b0;
      RStat_q3 <= #Tp 1'b0;
      ScanStat_q1  <= #Tp 1'b0;
      ScanStat_q2  <= #Tp 1'b0;
      SyncStatMdcEn <= #Tp 1'b0;
    end
  else
    begin
      WCtrlData_q1 <= #Tp WCtrlData;
      WCtrlData_q2 <= #Tp WCtrlData_q1;
      WCtrlData_q3 <= #Tp WCtrlData_q2;
      RStat_q1 <= #Tp RStat;
      RStat_q2 <= #Tp RStat_q1;
      RStat_q3 <= #Tp RStat_q2;
      ScanStat_q1  <= #Tp ScanStat;
      ScanStat_q2  <= #Tp ScanStat_q1;
      if(MdcEn)
        SyncStatMdcEn  <= #Tp ScanStat_q2;
    end
end
// Generation of the Start Commands (Write Control Data or Read Status)
begin
  if(Reset)
    begin
      WCtrlDataStart <= #Tp 1'b0;
      WCtrlDataStart_q <= #Tp 1'b0;
      RStatStart <= #Tp 1'b0;
    end
  else
    begin
      if(EndBusy)
        begin
        end
      else
        begin
          if(WCtrlData_q2 & ~WCtrlData_q3)
            WCtrlDataStart <= #Tp 1'b1;
          if(RStat_q2 & ~RStat_q3)
            RStatStart <= #Tp 1'b1;
          WCtrlDataStart_q <= #Tp WCtrlDataStart;
        end
    end
end
// Generation of the Nvalid signal (indicates when the status is invalid)
begin
  if(Reset)
    Nvalid <= #Tp 1'b0;
  else
    begin
      if(~InProgress_q2 & InProgress_q3)
        begin
          Nvalid <= #Tp 1'b0;
        end
      else
        begin
          if(ScanStat_q2  & ~SyncStatMdcEn)
            Nvalid <= #Tp 1'b1;
        end
    end
end
// Signals used for the generation of the Operation signals (positive edge)
begin
  if(Reset)
    begin
      WCtrlDataStart_q1 <= #Tp 1'b0;
      WCtrlDataStart_q2 <= #Tp 1'b0;
      RStatStart_q1 <= #Tp 1'b0;
      RStatStart_q2 <= #Tp 1'b0;
      InProgress_q1 <= #Tp 1'b0;
      InProgress_q2 <= #Tp 1'b0;
      InProgress_q3 <= #Tp 1'b0;
     LatchByte0_d <= #Tp 1'b0;
     LatchByte1_d <= #Tp 1'b0;
     LatchByte <= #Tp 2'b00;
    end
  else
    begin
      if(MdcEn)
        begin
          WCtrlDataStart_q1 <= #Tp WCtrlDataStart;
          WCtrlDataStart_q2 <= #Tp WCtrlDataStart_q1;
          RStatStart_q1 <= #Tp RStatStart;
          RStatStart_q2 <= #Tp RStatStart_q1;
          LatchByte[0] <= #Tp LatchByte0_d;
          LatchByte[1] <= #Tp LatchByte1_d;
          LatchByte0_d <= #Tp LatchByte0_d2;
          LatchByte1_d <= #Tp LatchByte1_d2;
          InProgress_q1 <= #Tp InProgress;
          InProgress_q2 <= #Tp InProgress_q1;
          InProgress_q3 <= #Tp InProgress_q2;
        end
    end
end
// Generation of the Operation signals
assign WriteDataOp  = WCtrlDataStart_q1 & ~WCtrlDataStart_q2;
assign ReadStatusOp = RStatStart_q1     & ~RStatStart_q2;
assign ScanStatusOp = SyncStatMdcEn     & ~InProgress & ~InProgress_q1 & ~InProgress_q2;
assign StartOp      = WriteDataOp | ReadStatusOp | ScanStatusOp;
// Busy
assign Busy = WCtrlDataStart | RStatStart | SyncStatMdcEn | EndBusy | InProgress | InProgress_q3 | Nvalid;
// Generation of the InProgress signal (indicates when an operation is in progress)
// Generation of the WriteOp signal (indicates when a write is in progress)
begin
  if(Reset)
    begin
      InProgress <= #Tp 1'b0;
      WriteOp <= #Tp 1'b0;
    end
  else
    begin
      if(MdcEn)
        begin
          if(StartOp)
            begin
              if(~InProgress)
                WriteOp <= #Tp WriteDataOp;
              InProgress <= #Tp 1'b1;
            end
          else
            begin
              if(EndOp)
                begin
                end
            end
        end
    end
end
// Bit Counter counts from 0 to 63 (from 32 to 63 when NoPre is asserted)
begin
  if(Reset)
    BitCounter[6:0] <= #Tp 7'h0;
  else
    begin
      if(MdcEn)
        begin
          if(InProgress)
            begin
              if(NoPre & ( BitCounter == 7'h0 ))
                BitCounter[6:0] <= #Tp 7'h21;
              else
                BitCounter[6:0] <= #Tp BitCounter[6:0] + 1'b1;
            end
          else
        end
    end
end
// Operation ends when the Bit Counter reaches 63
assign EndOp = BitCounter==63;
assign ByteSelect[0] = InProgress & ((NoPre & (BitCounter == 7'h0)) | (~NoPre & (BitCounter == 7'h20)));
assign ByteSelect[1] = InProgress & (BitCounter == 7'h28);
assign ByteSelect[2] = InProgress & WriteOp & (BitCounter == 7'h30);
assign ByteSelect[3] = InProgress & WriteOp & (BitCounter == 7'h38);
assign LatchByte1_d2 = InProgress & ~WriteOp & BitCounter == 7'h37;
assign LatchByte0_d2 = InProgress & ~WriteOp & BitCounter == 7'h3F;
// Connecting the Clock Generator Module
eth_clockgen clkgen(.Clk(Clk), .Reset(Reset), .Divider(Divider[7:0]), .MdcEn(MdcEn), .MdcEn_n(MdcEn_n), .Mdc(Mdc)
// Connecting the Shift Register Module
eth_shiftreg shftrg(.Clk(Clk), .Reset(Reset), .MdcEn_n(MdcEn_n), .Mdi(Mdi), .Fiad(Fiad), .Rgad(Rgad),
                    .CtrlData(CtrlData), .WriteOp(WriteOp), .ByteSelect(ByteSelect), .LatchByte(LatchByte),
                    .ShiftedBit(ShiftedBit), .Prsd(Prsd), .LinkFail(LinkFail)
// Connecting the Output Control Module
eth_outputcontrol outctrl(.Clk(Clk), .Reset(Reset), .MdcEn_n(MdcEn_n), .InProgress(InProgress),
                          .ShiftedBit(ShiftedBit), .BitCounter(BitCounter), .WriteOp(WriteOp), .NoPre(NoPre),
                          .Mdo(Mdo), .MdoEn(MdoEn)
endmodule
发表于 2008-10-12 21:21:16 | 显示全部楼层
module eth_miim
  Clk,
  Reset,
  Divider,
  NoPre,
  CtrlData,
  Rgad,
  Fiad,
  WCtrlData,
  RStat,
  ScanStat,
  Mdi,
  Mdo,
  MdoEn,
  Mdc,
  Busy,
  Prsd,
  LinkFail,
  Nvalid,
  WCtrlDataStart,
  RStatStart,
  UpdateMIIRX_DATAReg
parameter Tp = 1;
reg           Nvalid;
wire          LatchByte1_d2;
wire          LatchByte0_d2;
reg           LatchByte1_d;
reg           LatchByte0_d;
begin
  if(Reset)
    begin
    end
  else
    begin
    end
end
begin
  if(Reset)
  else
  else
end
begin
  if(Reset)
    begin
    end
  else
    begin
      if(MdcEn)
    end
end
begin
  if(Reset)
    begin
    end
  else
    begin
      if(EndBusy)
        begin
        end
      else
        begin
        end
    end
end
begin
  if(Reset)
    Nvalid <= #Tp 1'b0;
  else
    begin
        begin
          Nvalid <= #Tp 1'b0;
        end
      else
        begin
            Nvalid <= #Tp 1'b1;
        end
    end
end
begin
  if(Reset)
    begin
    end
  else
    begin
      if(MdcEn)
        begin
        end
    end
end
// Busy
begin
  if(Reset)
    begin
    end
  else
    begin
      if(MdcEn)
        begin
          if(StartOp)
            begin
              if(~InProgress)
            end
          else
            begin
              if(EndOp)
                begin
                end
            end
        end
    end
end
begin
  if(Reset)
  else
    begin
      if(MdcEn)
        begin
          if(InProgress)
            begin
              else
            end
          else
        end
    end
end
endmodule
发表于 2009-1-8 15:22:49 | 显示全部楼层
以太网的
你的这个我也在看,如果可以的话我们能够交个朋友吗,我的qq240844155希望可以和你交流一下看法
发表于 2012-9-8 15:16:29 | 显示全部楼层
楼上两位,我现在再看这段程序,非常希望能和你们交流一下。QQ:675819058
GMT+8, 2025-10-26 04:23 , Processed in 0.021052 second(s), 5 queries , Gzip On, Redis On.
