查看: 3033|回复: 5
opa 闭环特性仿真
发表于 2008-10-7 10:55:15 | 显示全部楼层 |阅读模式
侧重opa闭环特性设计时,应主要仿真哪些参数?应该做怎样的仿真?
发表于 2008-10-7 12:52:01 | 显示全部楼层
setting time,包括大信号和小信号,stability,UBW,PSRR,input-refered noise......
 楼主| 发表于 2008-10-7 14:57:47 | 显示全部楼层
那负载特性呢?对于外电路的要求呢?需不需要仿真具体的实现放大5倍,或者积分的性能?
发表于 2008-10-7 18:09:14 | 显示全部楼层
这些仿真都要针对你的应用了
比如一个内部的OP&一个驱动音箱的op要求是不一样的
发表于 2009-2-27 17:27:39 | 显示全部楼层
resistive and capacitive load simulation verification~~
发表于 2009-3-3 15:08:58 | 显示全部楼层
Of course you have to simulate those.  Simulate AC and transient to see if your closed loop gain in what you want (say, 5 in your case).  If you see a high loop gain results from your AC simulation, then you should see a very close to gain of 5 in your transient simulation.
Hope this helps.
GMT+8, 2025-12-28 10:29 , Processed in 0.026335 second(s), 5 queries , Gzip On, Redis On.
