查看: 7625|回复: 30
Signal Processing Fundamentals and Applications for Communications
发表于 2008-9-29 20:13:59 | 显示全部楼层 |阅读模式
2002年的書
About the Author
Dr. John Minkoff, is a Staff Scientist in the ITT Aerospace Communications Division, Clifton, NJ. He received his B.S., M.S. and Ph.D. in electrical engineering from Columbia University.
目录
Contents
Preface xi
Acknowledgments xiii
1 Introduction—Fundamentals of Receivers 1
1.1 Scope and Purpose of the Book 1
1.2 A Brief History of Sensing Systems, Their Influence on Signal Processing Development and Applications, and Receiver Fundamentals 4
2 Review of Probability 15
2.1 Bernoulli Trials—The Binomial Distribution 15
2.2 The Poisson Distribution 17
2.3 The Exponential Distribution 18
2.4 The Gaussian Distribution 19
2.5 The Rayleigh and Rice Distributions 19
2.6 Joint Distributions, Conditional Distributions, and Bayes’ Theorem 19
2.7 Characteristic Functions 21
2.8 The Law of Large Numbers 24
2.9 The Central Limit Theorem 24
2.10 Approximations to the Gaussian Distribution 27
2.11 Functions of a Random Variable 29
Exercises for Chapter 2 30
3 Review of Noise and Random Processes 33
3.1 Introduction—Correlation Functions and Power Spectral Densities 33
3.2 Types of Noise 37
3.3 Power Spectral Density of Thermal Noise—Nyquist’s Theorem 39
3.4 Power Spectral Density of Shot Noise 41
3.5 Shot Noise and Optical Receivers—The Quantum Limit 46
3.6 Noise Statistics—Shot Noise in RF and Optical Systems 50
3.7 Noise Figure and Noise Temperature 56
3.8 Noise Figure of an Attenuator 59
3.9 Applications—Noise Power Measurements, SNR 60
3.10 Connections with Statistical Physics 65
Exercises for Chapter 3 68
4 Continuous and Discrete-Time Signals 75
4.1 The Sampling Theorem and Oversampling 75
4.1.1 Application of the Sampling Theorem to Delay of Discrete-Time Signals 85
4.2 The Sampling Theorem for Bandpass Carrier Signals 88
4.3 Signal Duration and Bandwidth 90
4.4 The Analytic Signal 92
4.5 Processing of Continuous and Discrete-Time Signals 97
Exercises for Chapter 4 106
5 Detection of Signals in Noise 109
5.1 Statistical Decision Theory—The Likelihood Ratio Test 109
5.2 Decision Criteria—Bayes, Maximum Likelihood, and Neyman-Pearson 111
5.3 Implementation of Decision Criteria 115
5.3.1 Gaussian Noise 116
5.3.2 Shot Noise—Poisson Distribution 120
5.4 Correlation Detection: The Matched Filter—I 123
5.4.1 The Gaussian Channel 123
5.4.2 The Shot Noise Channel 131
5.5 The Matched Filter—II 133
Exercises for Chapter 5 136
6 Coherent and Noncoherent Detection and Processing 145
6.1 Ideal Noncoherent Detection of a Single Pulse 146
6.2 Comparison of Coherent and Noncoherent Detection of a Single Pulse 153
6.3 Improvement in SNR by Coherent and Noncoherent Integration 159
6.3.1 Noncoherent Integration 160
6.3.2 Coherent Integration 167
6.4 Performance of Coherent and Noncoherent Integration 173
6.4.1 Noncoherent Integration 173
6.4.2 Coherent Integration 175
6.5 Summary of Coherent and Noncoherent Detection and Processing 178
Exercises for Chapter 6 180
7 Parameter Estimation and Applications 183
7.1 Estimation of Range to a Target 184
7.2 Generalized Parameter Estimation 195
7.2.1 The Cramer-Rao Lower Bound on the Variance of an Estimator 196
7.2.2 Maximum-Likelihood Estimation 199
7.3 Applications of Maximum-Likelihood Estimation to Sensor Measurements 200
7.3.1 Calculation of the Cramer-Rao Bound for Coherent and Noncoherent Observations 202
7.4 Application of Parameter Estimation to Tracking and Prediction 209
Exercises for Chapter 7 216
8 Waveform Analysis, Range-Doppler Resolution, and Ambiguity 221
8.1 Waveform Analysis 222
8.2 Range-Doppler Resolution and Ambiguity—The Generalized Ambiguity Function 227
Exercises for Chapter 8 235
9 Large Time Bandwidth Waveforms 237
9.1 Chirp Waveforms and Pulse Compression 239
9.2 Doppler-Invariant Properties of Chirp Waveforms 246
9.3 Hyperbolic Frequency Modulation (HFM) 251
9.4 Ambiguity Functions for Large BT Waveforms 254
9.5 Coded Waveforms 257
Exercises for Chapter 9 260
10 Generalized Coherent and Noncoherent Detection and Processing 263
10.1 Noncoherent Detection of a Single Pulse 264
10.2 Coherent and Noncoherent Integration 267
Exercises for Chapter 10 270
11 Systems Considerations 271
11.1 Beampatterns and Gain of Antennas and Arrays 271
11.2 The Radar and Sonar Equations 279
11.3 The Search Problem 282
11.4 Specification of the False-Alarm Probability, Pfa 284
Appendix A: Table of Values of the Error
Function 287
References 293
About the Author 297
Index 299
1580533604.pdf
2.66 MB, 下载次数: 204 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-10-1 01:22:15 | 显示全部楼层
好书
真的是好书    外国的就是不一样啊
发表于 2008-10-11 23:28:38 | 显示全部楼层
thanks you for your sharing
发表于 2009-2-21 15:00:01 | 显示全部楼层
收下了,多谢
发表于 2009-3-9 19:52:21 | 显示全部楼层
ssssssssssssssss
发表于 2009-3-18 10:28:42 | 显示全部楼层
好书,顶一个
发表于 2009-3-21 00:08:26 | 显示全部楼层
好书。见解清楚,经典!谢谢!
发表于 2009-3-21 13:32:32 | 显示全部楼层
发表于 2009-5-16 08:29:13 | 显示全部楼层
最近重要学习这方面的东西,谢谢楼主的分享
发表于 2009-5-21 22:25:29 | 显示全部楼层
谢谢LZ的分享
GMT+8, 2025-12-27 11:05 , Processed in 0.049555 second(s), 9 queries , Gzip On, Redis On.
