查看: 5110|回复: 14
BER simulation
发表于 2008-9-16 15:38:41 | 显示全部楼层 |阅读模式
List of Figures 4
1. Overview 5
2. Simulation Setup and Block Diagram 6
2.1. Monte-Carlo Simulation Technique 6
2.2. Serial to Parallel Converter 7
2.3. /4 - DQPSK Encoder 7
2.4. Transmit Filter 7
2.5. Delays 7
2.6. Channel Simulators 7
2.7. Receive Filter 7
2.8. /4-DQPSK Decoder 7
2.9. Parallel to Serial Converter 8
2.10. Comparator and BER Counter 8
2.11. Noise Power Calculations 8
3. /4 Shifted Differential Quadrature Phase Shift Keying (DQPSK) 9
3.1. I and Q Components 9
3.2. Phase Shift Mapping 9
3.3. Constellation 9
3.4. /4-DQPSK Encoder Implementation 10
3.5. /4-DQPSK Decoder Implementation 10
4. Rayleigh Fading Envelope Generation 11
4.1. Spectral Shaping Filter 11
4.2. Fade Power Adjustment 12
4.3. Simulated Envelope 12
4.4. Faded SNR per bit 13
5. Simulation Results 14
5.1. Simulation Parameters 14
5.2. Case - I 14
5.3. Case II 15
5.4. Case III 15
5.5. Comprehensive Plot 15
5.6. Notes 15
6. MATLAB Modules for Simulation Blocks 18
6.1. Serial To Parallel Converter 18
6.2. /4-DQPSK Encoder 18
6.3. Transmit Filter 19
6.4. Rayleigh Fading Generator 19
6.5. Receive Filter 20
6.6. Coherent /4-DQPSK Decoder 21
6.7. /4-QPSK Encoder/Decoder (without Differential Encoding/Decoding) 21
7. MATLAB Source Code 22
7.1. Case-I : AWGN Channel 22
7.2. Case-II : LOS + Rayleigh Fading 23
EECS 865 SIMULATION PROJECT 3
7.3. Case-III : 2-ray Rayleigh (variable delays) 24
8. Appendix A - Raised Cosine Filtering 27
8.1. Description 27
8.2. Design 28
8.3. MATLAB Code 29
9. Appendix B - Rayleigh Fading Generation (Clarke/Gans Model) 31
9.1. Result 31
9.2. MATLAB Code
QPSKwithmatlabcode[1].pdf
268.64 KB, 下载次数: 36 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-9-16 21:57:22 | 显示全部楼层
顶一下
发表于 2008-9-16 23:03:20 | 显示全部楼层
xia look
发表于 2008-9-17 12:03:15 | 显示全部楼层
顶顶顶252
在遇到你之前,我对人世间是否有真正的圣人是怀疑的;而现在,我终于相信了!我曾经忘情于汉廷的歌赋,我曾经惊讶于李杜的诗才,我曾经流连于宋元的词曲;但现在,我才知道我有多么浅薄!
签名:初中化学教育论文
 楼主| 发表于 2008-9-17 22:48:57 | 显示全部楼层
ding a
 楼主| 发表于 2008-9-24 14:41:51 | 显示全部楼层
顶顶啊,哼哈阿
 楼主| 发表于 2008-9-25 09:44:21 | 显示全部楼层
顶啊,顶啊
发表于 2008-9-26 18:06:01 | 显示全部楼层
hao dong
 楼主| 发表于 2008-11-25 12:31:28 | 显示全部楼层
:lol
发表于 2009-2-25 21:07:58 | 显示全部楼层
谢谢楼主
GMT+8, 2025-11-16 02:05 , Processed in 0.031402 second(s), 8 queries , Gzip On, Redis On.
