楼主: zk52099
如何实现阻抗匹配
发表于 2008-9-12 06:02:09 | 显示全部楼层
wow gold,buy wow gold,cheap wow gold
wow gold of Silkroad power leveling  help from a level 60 in a matter of days, when typically Guild Wars power leveling it could take weeks of casual play time to reach the cheap wow gold  Anarchy Online same effect.All RPGs require characters to level up. Gaia power leveling Leveling up is typically a factor of time and Gaia power leveling energy - the more time buy wow gold you spend, the faster you level up! Knight Online power leveling wow gold There are ways to reduce this time wow 1000 gold though, to make Gaia power leveling leveling more efficient, less time consuming and in many ways, Tibia power leveling more fun. By cheap wow gold asking for the assistance of a higher-level character Gaia power leveling to take you through quests, dungeons and farming creatures, RF power leveling you can gain XP faster, buy wow gold at low risk and with far greater  Saga of Heroes power leveling efficiency. This process is called power leveling. We use 100 City Of Villains percent human gamers. While our world of warcraft gold gaming experts may not be Cabal power leveling able to acquire the one-of-a-kind Qiraji battle tank for you, Dofus power leveling we can perform practically any World of  Warcraft miracle to Archlord power leveling situate you optimally for questing, battling, or guild Ultima Online power leveling positioning.We provide a cheap WoW Power Leveling service for Guild Wars power leveling any level to level 70 wow gold on igonline.org
发表于 2008-10-9 13:13:53 | 显示全部楼层
是不是要加一个谐振网络就可以啊!
发表于 2008-10-15 10:39:50 | 显示全部楼层
对于带外信号可以使用滤波器,对于带内信号就没有好的办法了
发表于 2008-10-15 16:56:11 | 显示全部楼层
匹配也有很多种的,看你的要求了
发表于 2008-10-18 11:31:19 | 显示全部楼层
如果干扰信号是由功放的输入端引入的,则在输入加滤波。
发表于 2008-10-20 21:04:38 | 显示全部楼层
先看一看书吧,应该有很多都将到了
发表于 2009-4-28 21:52:45 | 显示全部楼层
了解了解
发表于 2009-5-2 09:55:15 | 显示全部楼层
学习,学习啊
发表于 2009-5-2 22:26:46 | 显示全部楼层
可用ADS软件中的Smith Chart工具
发表于 2009-5-13 14:00:55 | 显示全部楼层
这是两个问题,首先功放的匹配目的是进行最大功率的传送,当然是你感兴趣的功率,对于干扰信号,你尽可以再你的匹配电路中进行抑制。第一,需要达到你的所要信号的最大传输功率,即最大的增益,对于干扰信号,一个办法是在输入信号滤除,一个办法是在输出进行滤除。如果是放大器自身产生的,那么就是你的放大器设计有问题。显然可能出现自激的问题,这个问题就比较大了。
GMT+8, 2025-9-21 12:50 , Processed in 0.017885 second(s), 5 queries , Gzip On, Redis On.
